all about license
qibalsa
all about license
Post by qibalsa »
i want to ask about license,
1. if i have purchase the license, how i know the license will be expired? how to check it?
and is any command to do it (checking license)
2. is any interface for user only, that can do read only, not write/excute for this robotask?
3. if i want to upgrade version of robotask, can i do without new license?
is this license is for all version or not?
note : we use a robotask for company. for 1 computer.
thanks
Re: all about license
Your current license will not expire. You can use your current version forever. We keep all previous versions on our site and you always can download necessary version if it's necessary.
By default new license includes 1 year of free updates. This means that you can download and use new versions which has been released during 1 year since your purchase the license.
Your license will be valid for these versions too.
If you want to use latest version of RoboTask, but 1 year of free updates period is over, you should purchase at least 1 year of free updates.
We will send new registration key to you.
You can see all prices here: http://www.robotask.com/order/
qibalsa
Post by qibalsa »
so you mean current our robotask can use forever right, bacause we have version 5.2.1.681
and if i want to update version to lastest version, its only buy 1 year free update right?
for no 2. i mean
we have a user, but we want he can only read / view the process, he cant create new task / modify current task
is any option user interface for that user?
and how do we distinguish personal and company versions we already bought??
Yes
You can lock editor by password. See screenshot below:
qibalsa
Post by qibalsa »
i try to lock Task editor, and it seem i still can run task and edit task.
why ? is there i try on evaluation version ?
and if we has forget the password lock editor, how i can unlock it?
When you lock thask editor you can run task but you can't:
  • edit task
  • edit task tree
  • import task
  • edit list of global variables
You MUST remenber the password.
But if this trouble will happen refer to our support (http://www.robotask.com/contact/) and we will assist you to unlock it.
qibalsa
Post by qibalsa »
thank for your answer.
qibalsa
Post by qibalsa »
Hi Oleg,
how to run robotask with guest mode on windows, i mean without login admin.?
its possible to run from other komputer? for example, robotask installed on PC production, and user can access to run task from other computer that robotask.
Thank you.
qibalsa wrote:how to run robotask with guest mode on windows, i mean without login admin.?
You should run RoboTask as system service.
Read more about service mode here, please: http://www.robotask.com/help/index.php? ... cation.htm
Also read all related chapters.
qibalsa wrote:its possible to run from other komputer? for example, robotask installed on PC production, and user can access to run task from other computer that robotask.
You can access to RoboTask remotely via Network from other RoboTask on another computer.
Read more here here, please: http://www.robotask.com/help/index.php? ... etwork.htm
(and related chapters)
qibalsa
Post by qibalsa »
Hi Oleg ,
I want to ask,
Is possible to switch/exchange the license between 2 server ?
For example, i have server A. After project server A is already done, and i get new server 3 month later, whether the license can be exchanged?
How to solve this case without buy new license?
License has not been used up to 5 months and will be use for new server.
sorry for my bad english.
Thanks,
