Is it possible to change font size in email?
ntesla
Post by ntesla »
Hello
When programming Robotask to send an email using the 'Send Email' task under the 'Internet' tab, is it possible to specify that some text is larger than other text (ie, change the font size)?
Thank you in advance
Re: Is it possible to change font size in email?
Generally the email message it is only the ordinary text.
It doesn't affect email client.
The font size can be changed only in email client when you see the message. Also font size doesn't depend on message body.
Of course you can send messages in HTML format and set the desired font size directly in the message in HTML tags
ntesla
Post by ntesla »
Fantastic!
The HTML format suggestion did the trick.
I'm very grateful. Thank you for the prompt and super helpful feedback.
Regards
