Repeat sequence - Numbers increase.
kokas
Post by kokas »
Hello, I have read several threads and have not found what I want.
wish RoboTask open a shortcut to a web page in the url type a number and enter, example:
http://www.mywebsite.com/index.php?=1
repeat:
http://www.mywebsite.com/index.php?=2
repeat.
http://www.mywebsite.com/index.php?=3
Each time the sequence is repeated, RoboTask have to increase the number in ascending order.
how could I do this?
Thanks
Re: Repeat sequence - Numbers increase.
See my example.
This task opens 3 pages in the loop.
CatID=INTEGER|317955339
ExternalName=STRING|"Task372"
ID=INTEGER|1920243796
Name=STRING|"Repeat sequence - Numbers increase"
Name=STRING|"Create local variable ""NUM"" with value """""
varname=STRING|"NUM"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"3"
variable=STRING|"NUM"
Name=STRING|"Run ""//www.mywebsite.com/index.php?page={num} """
ifnonzero=STRING|"0"
program=STRING|"http://www.mywebsite.com/index.php?page={num}"
runas=STRING|"0"
wait=STRING|"0"
Save the task into a file and use menu Task -> Import to import the task into RoboTask.
kokas
Post by kokas »
Thanks Oleg, the code works fine.
But I have a little problem.
Each time you repeat the process, I always opens the same pages:
mywebsite.com/index.php=1
I want every time the process is repeated automatically increases in numbers.
First execution of the process, opens three pages 1 to 3
second execution of pages, open from 3-6
third: 6-9
following the process in the order of increasing numbers.
I have to open pages from number 1 to number 200850.
Thank.
You can save last sequence number into a file (for example) and read it at next start of the task.
But the task will be a bit more complex.
See below:
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
begin=STRING|"{start}"
end=STRING|"{finish}"
Enabled=INTEGER|0
runas=STRING|"0"
wait=STRING|"0"
[Actions\Action12\Params]
defh=STRING|"1"
defw=STRING|"0"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"http://www.mywebsite.com/index.php?page={num}"
position=STRING|"3"
title=STRING|"site"
width=STRING|"500"
[Actions\Action14]
Name=STRING|"Create text file {filename}"
[Actions\Action14\Params]
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{filename}"
line0=STRING|"{num}"
suppress=STRING|"1"
[Actions\Action15]
[Actions\Action15\Params]
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{num}"
value2=STRING|"200850"
[Actions\Action16]
Name=STRING|"Delete File"
[Actions\Action16\Params]
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{filename}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
[Actions\Action17]
Name=STRING|"Create local variable ""START"" with value """""
varname=STRING|"START"
Name=STRING|"Create local variable ""FINISH"" with value """""
varname=STRING|"FINISH"
Name=STRING|"Create local variable ""FILENAME"" with value ""{TempDir}\pagenum.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"{TempDir}\pagenum.txt"
Name=STRING|"Set variable ""START"" with value ""{TextFile({FileName})}"""
varvalue=STRING|"{TextFile({FileName})}"
Name=STRING|"Set variable ""FINISH"" with value ""{start}"""
varvalue=STRING|"{start}"
Name=STRING|"Increment variable ""start"""
incement=STRING|"1"
vaiable=STRING|"start"
Name=STRING|"Increment variable ""finish"""
incement=STRING|"3"
vaiable=STRING|"finish"
Enabled=INTEGER|0
Name=STRING|"Show ""{start}"""
msg0=STRING|"{start}"
msg1=STRING|"{Finish}"
msgcount=STRING|"2"
kokas
Post by kokas »
This works fine A million thanks I Appreciate it You are the best.
Have nice day.
