O verlapping tasks
deesloop
O verlapping tasks
Post by deesloop »
I want a task to run every minute
The task pings a location once a minute for 8 minutes
if those pings fail it is assumed there is a power failure, so initiates a shutdown 2 minutes after sending an email warning of this
As you can see there is a potential overlap of several minutes
How do i get round this please?
I did think of changinG the echo the date to c:\powerfail.txt and use a file monitor task but it isn't working...
Any pointers?
Thanks
CatID=INTEGER|0
ExternalName=STRING|"Task845"
ID=INTEGER|1708441467
Name=STRING|"Network up test"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Name=STRING|"Create local variable ""NOPING"" with value """""
varname=STRING|"NOPING"
Name=STRING|"End ping Loop"
Name=STRING|"if 8 failed pings"
[Actions\Action12\Params]
value1=STRING|"{PINGFAILS}"
value2=STRING|"8"
Name=STRING|"Warn of power off"
[Actions\Action13\Params]
attachcount=STRING|"0"
auth=STRING|"0"
charset=STRING|"iso-8859-1"
from=STRING|"robotask@domain.com"
host=STRING|"172.16.64.3"
html=STRING|"0"
msg0=STRING|"8 successive attempts to contact the network have failed"
msg1=STRING|"It is assumed there is a power failure and the servers will shut down in 2 minutes."
msgcount=STRING|"3"
password=STRING|"2642526733264732673612345"
passwordmode=STRING|"0"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"8th Network failure"
to=STRING|"me@domain.com"
[Actions\Action14]
Name=STRING|"Delay 2 mins"
[Actions\Action14\Params]
delay=STRING|"1200"
[Actions\Action15]
Name=STRING|"Create text file C:\POWERFAIL.TXT"
[Actions\Action15\Params]
encode=STRING|"0"
fileexists=STRING|"1"
filname=STRING|"C:\POWERFAIL.TXT"
line0=STRING|"{Time} {Date}"
suppress=STRING|"0"
[Actions\Action16]
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
[Actions\Action17]
Name=STRING|"Create local variable ""PINGFAILS"" with value ""0"""
varname=STRING|"PINGFAILS"
varvalue=STRING|"0"
Name=STRING|"Loop 8 times"
begin=STRING|"1"
end=STRING|"8"
ActionID=STRING|"A_INET_PING"
Name=STRING|"Ping network"
default=STRING|"-1"
host=STRING|"172.16.64.207"
timeout=STRING|"100"
variable=STRING|"NOPING"
Name=STRING|"If ping response"
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{NOPING}"
value2=STRING|"-1"
Name=STRING|"Else"
Name=STRING|"Increment PINGFAILS"
incement=STRING|"1"
vaiable=STRING|"PINGFAILS"
Name=STRING|"Send Email with attempt number"
auth=STRING|"0"
html=STRING|"0"
msg0=STRING|"The network at 172.16.64.xxx is not responding"
msg1=STRING|"This could be a power issue and requires the servers to be shut down."
msgcount=STRING|"2"
password=STRING|"2514526738246872545812345"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"No network response - Failure number {PINGFAILS}"
Name=STRING|"Wait a minute"
delay=STRING|"600"
UnigueID=INTEGER|16445953
id=STRING|"1NZHV21V"
interval=STRING|"60"
On file change task - never runs.
[code]
CatID=INTEGER|0
ExternalName=STRING|"Task5"
ID=INTEGER|1058326044
Name=STRING|"Check file and shutdown"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"C:\POWERFAIL.TXT"
hidden=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
ToRecycleBin=STRING|"0"
Name=STRING|"Send Email"
auth=STRING|"0"
html=STRING|"0"
msg0=STRING|"Enter message body"
password=STRING|"2488924938269912596212399"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"file change"
to=STRING|"me@domain.co.uk"
chg=STRING|"1"
chga=STRING|"0"
chgsl=STRING|"0"
chgsm=STRING|"0"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"C:\"
foldercount=STRING|"1"
incmask=STRING|"POWERFAIL.TXT"
interval=STRING|"10"
listmode=STRING|"1"
mon_files=STRING|"0"
mon_folders=STRING|"1"
new=STRING|"0"
pass=STRING|"0"
passmode=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"0"
Re: O verlapping tasks
What is the problem? Configure "Cyclic" event to start the task every 60 seconds.
Each task can be running only once at a time. Cyclic trigger will try to start the task every minute. If the task is already running you will see such message in the system log
Task "<task-name>" is already running
nothing more. The task will not be started twice.
deesloop
Post by deesloop »
Thanks fro that.
