Robotask object
colibri
Robotask object
Post by colibri »
hello,
I try to run a command line from vb with argument to RoboTask. Clearly, I want to get the result of my application in vb RoboTask.
Eric
Re: Robotask object
What result do you want to retrieve?
If you mean the output text of the utility the you can use the next command line:
cmd.exe /c myprogram.exe argument1 argument2 argument3 > c:\temp\output.txt
Command interpreter (cmd.exe) will catch the output of the utility and saves the output into text file.
