Confused about If-Then. Please help
misery
Post by misery »
Hi, I'm new to RoboTask and have the following issue. My task has an action step of highlighting a string of text from a website, and then (CTRL+C) to copy. I want to use the IF-THEN command to check
IF this copied string of text contains the word "roof"
THEN remove roof from the string before I paste it with the next step of the task.
I've read the manual but don't understand what First/Second operand are in my situation, or where I set up the IF-THEN function relative to my other steps in my task.
Please help. Thanks in advance
Re: Confused about If-Then. Please help
The action "If..Then" compares two values: 1-st operand and 2-nd operand
See the example below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task413"
ID=INTEGER|154462611
Name=STRING|"Create local variable ""FULLSTRING"" with value ""We want to find the word ""roof"" in the string""..."
Name=STRING|"Create local variable ""FULLSTRING"" with value ""We want to find the word ""roof"" in the string"""
varname=STRING|"FULLSTRING"
varvalue=STRING|"We want to find the word ""roof"" in the string"
Name=STRING|"Create local variable ""SUBSTRING"" with value ""roof"""
varname=STRING|"SUBSTRING"
varvalue=STRING|"roof"
operator=STRING|"6"
value1=STRING|"{SubString}"
value2=STRING|"{FullString}"
Name=STRING|"Show ""The word ""{SubString}"" is found in the string"""
msg0=STRING|"The word ""{SubString}"" is found in the string"
msg1=STRING|"""{FullString}"""
msgcount=STRING|"2"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""The word ""{SubString}"" is not found in the string"""
icon=STRING|"3"
msg0=STRING|"The word ""{SubString}"" is not found in the string"
msgcount=STRING|"2"
Save the text of the task into a file and use menu Task->Import to import the task into RoboTask.
