Barcode
rice1973
Barcode
Post by rice1973 »
Hello Oleg,
How can i capture a barcode scanner as a trigger? Barcode consists out of 9 numbers
Please advice
Robotask rules! :)
Re: Barcode
RoboTask can't work with barcode scanners directly.
If software for scanner can write the code into a file then you can configure File monitor trigger.
rice1973
Re: Barcode
Post by rice1973 »
OK,
But can it "grab" the input the scanner reads? It is a Symbol LS2208 that reads EAN13 barcode.
It reads a number printed in barcode, can Robotask on anyway catchthe read velaus?
Robotask rules! :)
Re: Barcode
Unfortunately no. There are many kinds of scanners with different interfaces (software and hardware)
I told that RoboTask can't work with scanner directly
