pause variable
rgonzalez
pause variable
Post by rgonzalez »
Is there a way to pause a task x amount of seconds carried by a variable? :|
For example:
Do something
x = 54*i seconds
Pause x seconds
Do something
x = 15*i-2 seconds
Pause x seconds
Thank you!
Re: pause variable
Look at the example below.
You can do this by using Simple loop
CatID=INTEGER|2099193306
ExternalName=STRING|"Task837"
ID=INTEGER|2072715731
Name=STRING|"set necessary delay in seconds"
Name=STRING|"//set necessary delay in seconds"
comment=STRING|"set necessary delay in seconds"
Name=STRING|"Set variable ""NUM"" with value ""5"""
varname=STRING|"NUM"
varvalue=STRING|"5"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"{num}"
Name=STRING|"Delay 1000 ms"
delay=STRING|"10"
Probably it's necessary to change Pause action in order to simplify the algorithm
Save the task text into a file and use menu Task->Import to import to RoboTask
rgonzalez
Re: pause variable
Post by rgonzalez »
thanks that works great :D
kristalharri
Re: pause variable
Post by kristalharri »
I agree..I am gonna execute this...It's favorably works for me...I have never seen such an easy method to use pause variable..It is mind bogglingly best...!!! :)
