FTP downlaod delay
stevefromdodge
FTP downlaod delay
Post by stevefromdodge »
We are using RoboTask to download files from a vendor via FTP. We are getting occasional corrupt files, because we are downloading the file before it is complete. The vendor is asking us to place a delay in our downloading task.
What's the best way to download all files in a directory that are older than 5 minutes?
Re: FTP downlaod delay
Look at my example below:
CatID=INTEGER|2099193306
ExternalName=STRING|"Task699"
ID=INTEGER|711012147
Name=STRING|"Create local variable ""FILENAME"" with value """"..."
Name=STRING|"Create local variable ""FILENAME"" with value """""
varname=STRING|"FILENAME"
ActionID=STRING|"A_SSLFTP_LOGON"
Name=STRING|"SSL FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"1"
port=STRING|"21"
proxypassword=STRING|"2616925200249402545615982"
proxytype=STRING|"3"
tlsmode=STRING|"0"
useproxy=STRING|"0"
username=STRING|"anonymous"
usessl2=STRING|"0"
usessl3=STRING|"0"
usestls=STRING|"1"
ActionID=STRING|"A_SSLFTP_FILELOOP"
Name=STRING|"SSL FTP File Loop"
createmode=STRING|"9"
createormodified=STRING|"1"
date1=STRING|"18991230"
date2=STRING|"18991230"
DuringMinutes=STRING|"1"
filenameonly=STRING|"0"
folder=STRING|"/incoming"
kind=STRING|"0"
OlderMinutes=STRING|"10"
sizesave=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"0"
ActionID=STRING|"A_SSLFTP_DOWNLOAD"
Name=STRING|"SSL FTP Download"
file=STRING|"{filename}"
folder=STRING|"c:\ftpfiles"
ifexists=STRING|"0"
You can download files in the loop. FTP File Loop have date (Date-Time) filter
See on the screenshot:
SSL FTP and sFTP File Loop have same filter.
