SFTP Sync
azecm
SFTP Sync
Post by azecm »
http://www.robotask.com/help/index.php?sftp_log_on.htm
Choose connection profile
"...save them into the separate profile..." how to save???
Which file format will it be?
Where to place it for Robotask to find it?
Re: SFTP Sync
The work of the plugin is supported by the console utility PSFTP.EXE from the PUTTY package (http://www.putty.org/).
In order to configure and save some own profile you have to use utility PUTTY. PSFTP utility uses only proxy settings from the profile.
Almost always the default profile is enough.
azecm
Re: SFTP Sync
Post by azecm »
only proxy settings
...so i can`t use private key file for authentication...
is that right?
...it`s pity...
