Check if task is running?
fodmob
Post by fodmob »
Does anyone know how to check in a task if another task is running at the moment?
Thanks in advance.
Re: Check if task is running?
You can use "Wait for Task" action to wait when specified task will be finished.
If the task is not running the action doesn't wait and goes to next action in current task
