Ftp Sync with deletion files
jamescabelo
Post by jamescabelo »
As seen in another topic here in the forum (but not answered correctly), I still have a doubt whether there is the possibility of making a RoboTask synchronization of deleted files between two folders.
For example, when a file was deleted in a folder (FTP), was deleted in the same destination folder as well and vice versa.
Thank you.
Re: Ftp Sync with deletion files
See options on the screenshot below
Exact copy means that the action copies newer files from the source folder to the target folder and then removes all files from the target folder that are absent in the source folder.
You can see this in the help
Pay attention that plain FTP and SFTP plugins have similar action with similar options
jamescabelo
That's not enough for me. Not how it works using Allway sync in both directions, synchronizing files with deletions and updates the files. Anyhow, thank you.
