Remove read only setting from a folder
thjmcd82
Post by thjmcd82 »
is there a way I can Remove read only setting from a folder using robo task?
Thanks
Re: Remove read only setting from a folder
Look at File Attributes action
It can set or remove any file attribute on file or folder
In order to remove Read Only attribute use these settings (see on screenshot):
