Weeknumber minus 1
rice1973
Weeknumber minus 1
Post by rice1973 »
Hello Oleg,
What do i have to change to set the week number minus 1 by the variable ; {WeekOfTheYear({Date})}
And at what day does the new week start? Is it on monday?
Kind regards,
Maurice
Robotask rules! :)
Re: Weeknumber minus 1
New week begins on Monday.
See the example below how to calculate WeekOfTheYear-1
CatID=INTEGER|317955339
ExternalName=STRING|"Task730"
ID=INTEGER|73766993
Name=STRING|"Week of the year - 1"
Name=STRING|"Create local variable ""WEEKNUM"" with value ""{WeekOfTheYear({Date})}"""
varname=STRING|"WEEKNUM"
varvalue=STRING|"{WeekOfTheYear({Date})}"
Name=STRING|"Increment variable ""WeekNum"""
incement=STRING|"-1"
vaiable=STRING|"WeekNum"
msg1=STRING|"Week of the Year: {WeekOfTheYear({Date})}"
msg2=STRING|"Week of the Year - 1: {WeekNum} "
msgcount=STRING|"3"
rice1973
Post by rice1973 »
Ok,
Is it not as simple as {IncDays(-1)} ?
Robotask rules! :)
What do you want to get: yesterday's date or number of previous week?
{IncDays(-1)} - the day number (not week number or date)
{DateIncDays(-1)} - the date of yesterday
rice1973
Post by rice1973 »
I want to get the number of previous week. :)
Robotask rules! :)
So, look at my example above.
Micha
Post by Micha »
Where to use the code when I want to use the variable? Should I copy the code to "Local variables"???
You can see the task and use task editor to edit it and see all parameters of each step
