robotask cannot delete files anymore?
jeroen123
Post by jeroen123 »
Hello Oleg,
'suddenly' RT takes a long time for deleting-file tasks;
the directory is normally available through explorer; and deleting files manually is easy..
any suggestion??
part of LOG below...
W: 8-10-2013 9:20:50: File "E:\TEMPPIC2\SMALL\1703.jpg" can't be deleted
W: 8-10-2013 9:20:50: An unknown error occurred. This is typically due to an invalid path in the source or destination. (1026)
W: 8-10-2013 9:21:14: File "E:\TEMPPIC2\SMALL\1707.jpg" can't be deleted
W: 8-10-2013 9:21:14: An unknown error occurred. This is typically due to an invalid path in the source or destination. (1026)
W: 8-10-2013 9:21:36: File "E:\TEMPPIC2\SMALL\1715.jpg" can't be deleted
W: 8-10-2013 9:21:36: An unknown error occurred. This is typically due to an invalid path in the source or destination. (1026)
W: 8-10-2013 9:21:56: File "E:\TEMPPIC2\SMALL\1720.jpg" can't be deleted
W: 8-10-2013 9:21:56: An unknown error occurred. This is typically due to an invalid path in the source or destination. (1026)
Re: robotask cannot delete files anymore?
The error message in the log is the system message. RoboTask get this message when it try to delete specified file.
Check the path, please. Maybe there are some mistakes in the path.
Also, it would be great if you will send your task and log of the task to me (via email to oleg(at)robotask.com) for investigation.
