Using Run Program to initiate logon
Patty S.
Post by Patty S. »
I've been working on a task that checks to see if a process is active by using the IsProcessExists variable. (Check to see if Skype is listed as a process)
If it is not listed then logon.
Run Program - my path\Skype.exe
parameters username and password.
The task will start Skype but will not pass the username and password. Any ideas how to accomplish this?
Re: Using Run Program to initiate logon
Are you sure that Skype can process username and password in command line?
I think that no.
See here about possible command line parameters of Skype
