To Oleg: Selecting Groups of Files
Red_Eye
Post by Red_Eye »
Hi Oleg, I see you are webmaster here  I am new to this software and would like some help to see if Robotask can do the following:
I have a folder called "MP3Files" with about 1000 mp3 files in it on my C: drive. I want to move the first 10 files from the folder into a new folder called "CD1". Then, as part of the same task, move the next 10 files into a new folder called "CD2". This will continue until the "MP3Files" folder is empty.
The folders called "CD1", "CD2" ... "CD500" etc already exist on my C: drive. The precise number of files in the "MP3Files" folder will vary from time to time.
I do not know how to implement this into a task though. Is it a loop? Could you please write it here and I will modify it and import it to Robotask?
Thank you for your help and a good program.
Excuse me for long silence. It's not difficult. You may use the File loop and two variables for numeration.
See rask below. This task can create folders CD1..CDN if needed.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task92"
ID=INTEGER|1065926379
Name=STRING|"Selecting Groups of Files"
Name=STRING|"Set variable ""FOLDERNUM"" with value ""0"""
varname=STRING|"FOLDERNUM"
varvalue=STRING|"0"
Name=STRING|"Remove variable ""FOLDERNUM"""
[Actions\Action12\Params]
Name=STRING|"Remove variable ""NUMFILE"""
[Actions\Action13\Params]
varname=STRING|"NUMFILE"
Name=STRING|"Set variable ""NUMFILE"" with value ""0"""
varvalue=STRING|"0"
Name=STRING|"File Loop"
date1=STRING|"20041203"
date2=STRING|"20041203"
destvar=STRING|"FILENAME"
file0=STRING|"C:\MP3Files\*.mp3"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Create Folder (c:\cd{FolderNum})"
newfolder=STRING|"c:\cd{FolderNum}"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"c:\cd{FolderNum}"
f_count=STRING|"1"
file0=STRING|"{FileName}"
ifexists=STRING|"0"
move=STRING|"1"
subdir=STRING|"0"
Name=STRING|"Increment variable ""NumFile"""
incement=STRING|"1"
vaiable=STRING|"NumFile"
operator=STRING|"2"
type=STRING|"1"
value1=STRING|"{NumFile}"
value2=STRING|"10"
Name=STRING|"Increment variable ""FolderNum"""
incement=STRING|"1"
vaiable=STRING|"FolderNum"
varvalue=STRING|"0"
;end of task
