run through a list of filenames and email
deesloop
Post by deesloop »
i have some files In a folder.
They are all date_xxxx_costs.pdf
What I want to do is run through the list and email each file indivudally to
xxxxfile@domain.com
I was thinking of using a variable emailto
then using strextra grab characters 12-15 and assign that string to the variable emailto
Then ammend emailto variable to be emailto & "domain.com"
I'm struggline to do this though
Can a variable be set to the value and then manipulated a string?
Re: run through a list of filenames and email
Send several examples of the real file names.
I will try to write the example but I need to test it on real names.
There may be some nuances.
See the example below.
This will be something similar to this:
CatID=INTEGER|2099193306
ExternalName=STRING|"Task667"
ID=INTEGER|1759461252
Name=STRING|"Send files individually"
Name=STRING|"Create local variable ""FOLDER"" with value ""D:\incoming\pdf\"""
varname=STRING|"FOLDER"
varvalue=STRING|"D:\incoming\pdf\"
Name=STRING|"Create local variable ""CFILE"" with value """""
varname=STRING|"CFILE"
Name=STRING|"Create local variable ""PART"" with value """""
varname=STRING|"PART"
Name=STRING|"File Loop"
date1=STRING|"20130919"
date2=STRING|"20130919"
destvar=STRING|"CFILE"
DuringMinutes=STRING|"1"
file0=STRING|"{folder}\*.pdf"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
WithoutPath=STRING|"1"
ActionID=STRING|"A_STR_BETWEEN"
Name=STRING|"STR Between"
begin=STRING|"_"
end=STRING|"_"
save=STRING|"0"
source=STRING|"{cfile}"
startpos=STRING|"1"
variable=STRING|"part"
Name=STRING|"Show ""{part}file@domain.com"""
msg0=STRING|"{part}file@domain.com"
Enabled=INTEGER|0
Name=STRING|"Send Email"
attach0=STRING|"{cfile}"
attachcount=STRING|"1"
auth=STRING|"0"
charset=STRING|"iso-8859-1"
from=STRING|"user@host.com"
host=STRING|"host.com"
html=STRING|"0"
msg0=STRING|"See file in attacment {cfile}"
password=STRING|"2616924941259692596116055"
passwordmode=STRING|"0"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"Enter subject"
to=STRING|"{part}file@domain.com"
Also look at the step #7 (send email) You can enable it and correct parameters to necessary values.
But mechanism will be the same.
