puttyguy
Post
by puttyguy »
I'm trying to set up a macro that simply copies, pastes, and executes commands in SSH.
I have a list of files (in a plain text file) that I want to delete from server:
Code:
rm -f "file1.htm"
rm -f "file2.htm"
rm -f "file3.htm"
rm -f "file4.htm"
rm -f "file5.htm"
rm -f "file6.htm"
... and many thousands more.
I simply want RoboTask to copy each line into Putty (one-by-one) and press enter, thus executing the command.
Any help is appreciated.
- Site Admin
Post
by Oleg »
The task will be similar to this example.
You can specify text in the loop directly. But you can specify external text file in the loop.
CatID=INTEGER|1503011508
ExternalName=STRING|"Task49"
ID=INTEGER|902018506
Name=STRING|"Repetitive SFTP task"
Name=STRING|"Create local variable ""CURRENTFILE"" with value """""
varname=STRING|"CURRENTFILE"
Name=STRING|"Create local variable ""OUT"" with value """""
varname=STRING|"OUT"
ActionID=STRING|"A_SFTP_LOGON"
Name=STRING|"SFTP Open (username@servername)"
host=STRING|"servername"
password=STRING|"8300183858849008361683093"
passwordmode=STRING|"0"
port=STRING|"22"
username=STRING|"username"
Name=STRING|"Text Loop"
destvar=STRING|"CURRENTFILE"
line0=STRING|"file1.htm"
line1=STRING|"file2.htm"
line2=STRING|"file3.htm"
line3=STRING|"file4.htm"
line4=STRING|"file5.htm"
line5=STRING|"file6.htm"
linecount=STRING|"6"
sourcetext=STRING|"1"
ActionID=STRING|"A_SFTP_COMMAND"
Name=STRING|"SFTP command (rm -f ""{CurrentFile}"")"
command=STRING|"rm -f ""{CurrentFile}"""
variable=STRING|"out"
message=STRING|"{out}"
Save the task into a file and use menu Task->Import in order to import into RoboTask.
