Export/Email file name and size of a spedific folder
kkhalid
Post by kkhalid »
Is there a way to email the content of a folder ( Filename and Size) using robotask. Need to run this task every morning.
Rgds,
Kash
Re: Export/Email file name and size of a spedific folder
Yes, of course.
Look at the example below
CatID=INTEGER|2099193306
ExternalName=STRING|"Task417"
ID=INTEGER|604131886
Name=STRING|"Send content of the folder"
Name=STRING|"Create local variable ""FOLDER"" with value ""D:\incoming"""
varname=STRING|"FOLDER"
varvalue=STRING|"D:\incoming"
Name=STRING|"Create local variable ""TEXT"" with value ""Content of the folder {Folder}:{EOL}{EOL}"""
varname=STRING|"TEXT"
varvalue=STRING|"Content of the folder {Folder}:{EOL}{EOL}"
Name=STRING|"Create local variable ""FILENAME"" with value """""
varname=STRING|"FILENAME"
Name=STRING|"Create local variable ""FILESIZE"" with value """""
varname=STRING|"FILESIZE"
Name=STRING|"File Loop"
date1=STRING|"20130830"
date2=STRING|"20130830"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"{Folder}\*.*"
savesize=STRING|"1"
savevar=STRING|"FILESIZE"
searchkind=STRING|"0"
sort=STRING|"1"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""TEXT"" with value ""{TEXT}{FILENAME};  {FILESIZE} bytes{eol}"""
varvalue=STRING|"{TEXT}{FILENAME};  {FILESIZE} bytes{eol}"
Name=STRING|"Send Email"
attachcount=STRING|"0"
auth=STRING|"0"
charset=STRING|"Windows-1252"
from=STRING|"user@domain.com"
host=STRING|"mail.domain.com"
html=STRING|"0"
msg0=STRING|"{text}"
password=STRING|"2565725452246852545525706"
passwordmode=STRING|"0"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"List of folder {folder}"
to=STRING|"admin@domain.com"
UnigueID=INTEGER|16445953
id=STRING|"INVN7UIA"
periodicity=STRING|"0"
startdate=STRING|"41516"
time0=STRING|"34200000"
timecount=STRING|"1"
Save the task into a file and use menu Task -> import in order to import into RoboTask
Of course you should change parameters of the action "Send email" to your own.
