keystrokes
poconnor1
keystrokes
Post by poconnor1 »
Robotask will open the program I require but I need it to emulate Ctrl
and Alt keys. I believe I'v done this is Enter Keystrokes, but nothing
happens in the opened program.
Any suggestions?????
thanks,
Peter
keystrokes
If you start any program, you need to insert a pause between "Run program" and "Send Keystroke" actions. Probably the application not ready for input any keys.
RoboTask can emulate CTRL, ALT and SHIFT key combination. For example CTRL-SHIFT-8 or CTRL-ALT-W. In configuration form of Key Stroke use the "Insert a key" button and choose "Key combination..." option.
Single pressings of Alt, Ctrl, Shift keys is not supported for the present. It will be implemented in next release.
