Copy files that were created yesterday
kkhalid
Post by kkhalid »
Hello
Is there any way i can make robocopy to copy my backup files from server a to server b that were done last night and not copy the files that were created a day earlier.
kash
Re: Copy files that were created yesterday
See examples below.
Save the text of the task as a file and use menu Task->Import in order to import into RoboTask
1-st example copies files which newer than 1 day (24 hours). It's enough to use date filter of File Loop action
CatID=INTEGER|1663346572
ExternalName=STRING|"Task289"
ID=INTEGER|1351036233
Name=STRING|"copy files last 24 hours"
message=STRING|"******** begin ***************"
Name=STRING|"Create local variable ""FILENAME"" with value """""
varname=STRING|"FILENAME"
Name=STRING|"File Loop"
createmode=STRING|"3"
createormodified=STRING|"1"
date1=STRING|"20130813"
date2=STRING|"20130813"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"D:\incoming\*.*"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"d:\dest"
f_count=STRING|"1"
file0=STRING|"{filename}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"0"
subdir=STRING|"0"
system=STRING|"1"
message=STRING|"******** end ***************"
2-nd example is more complex and copies only yesterday's files
ExternalName=STRING|"Task305"
ID=INTEGER|1779031543
Name=STRING|"copy only yesterday files"
ToLog=INTEGER|2
[Actions\Action12\Params]
Name=STRING|"Create local variable ""FILETIME"" with value """""
varname=STRING|"FILETIME"
DuringDays=STRING|"3"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"1"
timevar=STRING|"FILETIME"
operator=STRING|"2"
type=STRING|"2"
value1=STRING|"{filetime}"
value2=STRING|"{DateIncDays(-1)}"
operator=STRING|"5"
type=STRING|"2"
value2=STRING|"{Date}"
message=STRING|"copy file {filename}; {filetime}"
f_count=STRING|"1"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"0"
subdir=STRING|"0"
system=STRING|"1"
I hope this helps you
