FTP File Search?
acepm2
FTP File Search?
Post by acepm2 »
Hi everyone! While I consider myself new, I'm having a heck of a time trying to search my client's FTP site and download files. What I need to be able to accomplish is the ability to search for any new files that they have uploaded within the last 24 hours. I can log on, change directories, etc. I just cannot seem to grasp how to locate "NEW" files and then download them!!
Can someone please help point me in the right direction??
Thank you!!
Thom
Re: FTP File Search?
Look at the example below.
This task writes to task log only files which was updated at last day (24 hours)
You should have BASIC plugin for this task. Download it here: http://www.robotask.com/downloads/BasicForRoboTask.exe (the link always is on download page).
CatID=INTEGER|1663346572
ExternalName=STRING|"Task287"
ID=INTEGER|1525567110
Name=STRING|"Date filter on FTP"
ToLog=INTEGER|2
message=STRING|"******** begin ***************"
[Actions\Action12\Params]
message=STRING|"******** end ***************"
Name=STRING|"Create local variable ""FILENAME"" with value """""
varname=STRING|"FILENAME"
Name=STRING|"Create local variable ""FILETIME"" with value """""
varname=STRING|"FILETIME"
Name=STRING|"Create local variable ""DIFF"" with value """""
varname=STRING|"DIFF"
ActionID=STRING|"A_SSLFTP_LOGON"
Name=STRING|"SSL FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"1"
port=STRING|"21"
proxypassword=STRING|"2488924944267382673325199"
proxytype=STRING|"3"
tlsmode=STRING|"0"
useproxy=STRING|"0"
username=STRING|"anonymous"
usessl2=STRING|"0"
usessl3=STRING|"0"
usestls=STRING|"1"
ActionID=STRING|"A_SSLFTP_FILELOOP"
Name=STRING|"SSL FTP File Loop"
filenameonly=STRING|"0"
folder=STRING|"*.*"
kind=STRING|"0"
sizesave=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"1"
vartime=STRING|"FILETIME"
Name=STRING|"Evaluate"
expression=STRING|"datediff(""d"", cdate(""{fileTime}""), now)"
variable=STRING|"DIFF"
operator=STRING|"5"
type=STRING|"1"
value1=STRING|"{diff}"
value2=STRING|"1"
message=STRING|"{filename}; {filetime}; {diff}"
Save the task into a file and use menu Task -> Import in order to import it into RoboTask.
Just let me know if you need some comments or explanation for this task.
acepm2
Post by acepm2 »
Oleg,
I'm sorry. I'm lost. I installed the basic and entered the code as you stated but I don't see anything. I need this to "download" all the files that would have been uploaded within the last 24 hours.
Can you shed some light on this for me please?
Thank you!
Thom
Use "SSL FTP download" action to download a file
See corrected example, step #10. Now the task downloads necessary files into temporary folder
Pay attention that this is an example only. In any case You should adapt the task for your purposes.
ToLog=INTEGER|2
ActionID=STRING|"A_SSLFTP_DOWNLOAD"
Name=STRING|"SSL FTP Download"
file=STRING|"{filename}"
folder=STRING|"{TEMPDIR}"
ifexists=STRING|"1"
[Actions\Action13\Params]
passive=STRING|"1"
port=STRING|"21"
proxypassword=STRING|"2540124941259612545326480"
tlsmode=STRING|"0"
useproxy=STRING|"0"
usessl2=STRING|"0"
usessl3=STRING|"0"
usestls=STRING|"1"
folder=STRING|"*.*"
kind=STRING|"0"
sizesave=STRING|"0"
timesave=STRING|"1"
operator=STRING|"5"
type=STRING|"1"
value2=STRING|"1"
message=STRING|"Download {filename}; File time {filetime}; Age {diff} days"
