robotask starts task 3 times unwanted..?
jeroen123
Post by jeroen123 »
Dear Oleg,
pls see my task below:
do you see any reason why I should get 3 emails out of this? we get 3 emails when this task is run, sometimes just 2... :shock:
CatID=INTEGER|878771735
ContinueOnError=INTEGER|1
ExternalName=STRING|"Task36"
ID=INTEGER|242455673
Name=STRING|"S07 voorraad lijst NL from SQL"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Action28=FOLDER
Name=STRING|"Create local variable ""FILE"" with value ""E:\DATA\robotask\lijsten\voorraadlijst"""
varname=STRING|"FILE"
varvalue=STRING|"E:\DATA\robotask\lijsten\voorraadlijst"
Enabled=INTEGER|0
Name=STRING|"Create text file {file}.txt"
encode=STRING|"0"
fileexists=STRING|"1"
filname=STRING|"{file}.txt"
line0=STRING|"{value(0)};{value(1)};{value(3)};{value(2)};{value(4)};{value(5)};{value(6)};{value(7)};{value(8)};{value(9)};{value(10)};{value(11)};{value(12)};{value(13)};{value(14)};{value(15)}"
suppress=STRING|"0"
Name=STRING|"Create local variable ""FILE2"" with value ""E:\DATA\robotask\lijsten\onderweg"""
varname=STRING|"FILE2"
varvalue=STRING|"E:\DATA\robotask\lijsten\onderweg"
Name=STRING|"Delete File"
[Actions\Action12\Params]
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{file2}*.txt"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"1"
[Actions\Action13\Params]
Count=STRING|"1"
file0=STRING|"{file2}*.csv"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
[Actions\Action14]
Name=STRING|"Create text file {file2}@{date}.txt"
[Actions\Action14\Params]
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{file2}@{date}.txt"
line0=STRING|"Item#;Item description;vrrd"
suppress=STRING|"0"
[Actions\Action15]
Name=STRING|"Dataset Loop"
[Actions\Action15\Params]
commatext=STRING|"0"
connectionstring=STRING|"DSN=Unit 4 Multivers;UID=Oxxx;PWD=xxx;DB=MVL00650;SRVR=MVSERV"
override=STRING|"0"
password=STRING|"xxx"
sql=STRING|"""SELECT ARTIKEL.CDARTIKEL, ARTIKEL.OMSCHR, VOORRADEN.VOORRAAD"",""FROM SYSADM.ARTIKEL ARTIKEL, PUBLIC.VOORRADEN VOORRADEN"",""WHERE ARTIKEL.CDARTIKEL = VOORRADEN.CDARTIKEL AND ((VOORRADEN.CDMAGAZIJN='50'))"",""ORDER BY ARTIKEL.CDARTIKEL"""
timeout=STRING|"60"
var1=STRING|"FIELD"
var2=STRING|"VALUE"
withmemo=STRING|"0"
[Actions\Action16]
Enabled=INTEGER|0
Name=STRING|"Evaluate"
[Actions\Action16\Params]
expression=STRING|"{value(8)}-{value(9)}-{value(10)}"
variable=STRING|"ECO"
[Actions\Action17]
[Actions\Action17\Params]
encode=STRING|"0"
line0=STRING|"{value(0)};{value(1)};{value(2)}"
suppress=STRING|"0"
[Actions\Action18]
Enabled=INTEGER|0
Name=STRING|"Show ""Result = {ECO}"""
[Actions\Action18\Params]
msg0=STRING|"Result = {ECO}"
[Actions\Action19]
Count=STRING|"1"
file0=STRING|"{file}*.txt"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
[Actions\Action20]
Enabled=INTEGER|0
[Actions\Action20\Params]
encode=STRING|"0"
suppress=STRING|"0"
[Actions\Action21]
Name=STRING|"Rename File"
[Actions\Action21\Params]
file0=STRING|"{file2}@{date}.txt"
ifexists=STRING|"1"
mask=STRING|"{file2}@{date}.csv"
subdirs=STRING|"0"
[Actions\Action22]
[Actions\Action22\Params]
file0=STRING|"{file}@{date}.txt"
ifexists=STRING|"1"
mask=STRING|"{file}@{date}.csv"
subdirs=STRING|"0"
[Actions\Action23]
Name=STRING|"Text Loop"
[Actions\Action23\Params]
destvar=STRING|"VERT"
file=STRING|"E:\DATA\robotask\Lijsten\Vertegenwoordigers.txt"
linecount=STRING|"0"
sourcetext=STRING|"0"
[Actions\Action24]
Name=STRING|"Set variable ""EMAIL"" with value ""{VERT(0)}"""
[Actions\Action24\Params]
varname=STRING|"EMAIL"
varvalue=STRING|"{VERT(0)}"
[Actions\Action25]
Name=STRING|"Set variable ""VNAAM"" with value ""{VERT(1)}"""
[Actions\Action25\Params]
varname=STRING|"VNAAM"
varvalue=STRING|"{VERT(1)}"
[Actions\Action26]
Name=STRING|"Set variable ""ANAAM"" with value ""{VERT(2)}"""
[Actions\Action26\Params]
varname=STRING|"ANAAM"
varvalue=STRING|"{VERT(2)}"
[Actions\Action27]
Name=STRING|"Send Email"
[Actions\Action27\Params]
attach0=STRING|"{file}@{date}.csv"
attach1=STRING|"{file2}@{date}.csv"
attachcount=STRING|"2"
auth=STRING|"1"
charset=STRING|"iso-8859-1"
from=STRING|"YYY"
host=STRING|"YYY"
html=STRING|"1"
msg0=STRING|"Beste {VNAAM},<br><br>"
msg1=STRING|"Zie svp bijgaande lijst<br><br>"
msg12=STRING|"RBT-S07"
msg2=STRING|"Deze zijn in CSV formaat: en kunnen in excel worden geopend. SVP eerst excel openen, dan vanuit excel deze lijst openen."
msg3=STRING|"<br><br>"
msg4=STRING|"Vanaf nu krijgt u dagelijks een actuele voorraadlijst toegestuurd & een lijst 'onderweg': hierin staat welke goederen er per vandaag onderweg zijn: deze zijn binnen 3-4 weken hier."
msg5=STRING|"Zo heeft u meer inzicht in  'dat wat komen gaat'; helaas kunnen beide lijsten niet worden gecombineerd."
msg6=STRING|"<br><br>"
msg7=STRING|"Best regards,<br>"
msg8=STRING|"Jeanette"
msgcount=STRING|"13"
password=STRING|"XXX"
passwordmode=STRING|"0"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"voorraadlijst {date}  {time}H voor {VNAAM} {ANAAM}"
to=STRING|"{EMAIL}"
user=STRING|"jeroen"
[Actions\Action28]
Count=STRING|"1"
file0=STRING|"{file}*.csv"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
Name=STRING|"Create text file {file}@{date}.txt"
encode=STRING|"0"
filname=STRING|"{file}@{date}.txt"
line0=STRING|"Item#;Item description;P1;Cons;Inn;Out;vrrd;ECO"
suppress=STRING|"0"
connectionstring=STRING|"DSN=Unit 4 Multivers;UID=XXX;PWD=XXX;DB=MVL00650;SRVR=MVSERV"
override=STRING|"0"
sql=STRING|"""SELECT ARTIKEL.CDARTIKEL, ARTIKELOMSCHR.OMSCHR, ARTIKEL.PRIJSEXCL, ARTIKEL.VVCONSPRIJS, ARTIKEL.VVINNERQPCEVERKOOP, ARTIKEL.VVOPPRIJSLIJST, ARTIKEL.VVOUTERQPCE, VOORRADEN.CDMAGAZIJN, VOORRADEN.VOORRAAD, VOORRADEN.BESTELD, VOORRADEN.GERESERVEERD"",""FROM SYSADM.ARTIKEL ARTIKEL, SYSADM.ARTIKELOMSCHR ARTIKELOMSCHR, PUBLIC.VOORRADEN VOORRADEN"",""WHERE ARTIKEL.CDARTIKEL = VOORRADEN.CDARTIKEL AND ARTIKELOMSCHR.CDARTIKEL = ARTIKEL.CDARTIKEL AND ((ARTIKELOMSCHR.CDTAAL='N') AND (ARTIKEL.VVOPPRIJSLIJST>0) AND (VOORRADEN.CDMAGAZIJN='1'))"",""ORDER BY ARTIKEL.CDARTIKEL"""
timeout=STRING|"60"
var1=STRING|"FIELD"
var2=STRING|"VALUE"
withmemo=STRING|"0"
encode=STRING|"0"
line0=STRING|"{value(0)};{value(1)};{value(2)};{value(3)};{value(4)};{value(6)};{value(8)};{ECO}"
suppress=STRING|"0"
Enabled=INTEGER|0
UnigueID=INTEGER|17166849
id=STRING|"40XQ3P4V"
periodicity=STRING|"1"
periodparameter=STRING|"0111110"
startdate=STRING|"41383"
time0=STRING|"61200000"
timecount=STRING|"1"
Re: robotask starts task 3 times unwanted..?
You send email in the text loop (file E:\DATA\robotask\Lijsten\Vertegenwoordigers.txt) step #27
Unfortunately I don't see where you create the file E:\DATA\robotask\Lijsten\Vertegenwoordigers.txt.
Maybe you forgot this?
Amount of emails should be equal to amount of lines in the text E:\DATA\robotask\Lijsten\Vertegenwoordigers.txt
jeroen123
Post by jeroen123 »
Dear Oleg,
The file 'vertegenwoordigers.txt' is always in that directory; thats where I keep the names and emails. so this is available.
it contains 6 lines with emails; but each emailadres receives the email 3 times..
any idea how this can happen?
(other tasks with email function not seems to have this problem..)
in step 3 there is a header created for the TXT file: but sometimes we not see that header.
could it be that robotask jumps over tasks, or is too fast for tasks?
But I see that step #3 is "Delete file"...
Also I see that you use global variables. All variables are global by default and can be changed in another task.
I strongly recommend you to declare all necessary variables as local
You can do this at Local variables tab (see screenshot below)
Add the declaration of loop variables
jeroen123
Post by jeroen123 »
Dear Oleg,
still tasks run unwanted..
could it be that there is multiple versions of ROBOTASK running simultaniously?
in my taskmanager I see 3 lines:
how to check?
It seems you use RDC (remote desktop connection) and you have 3 sessions of user "administrator". Correct?
I recommend you to use different users for different sessions.
RoboTask can be started only once within one session. If you have several separated sessions then RoboTask can be started in each session.
We'll investigate the problem, probably we will add some mechanism to avoid of running RoboTask on one computer within separate sessions under the same user.
I recommend you to use such command line of RDC client:
mstsc /admin
In this case you will have only one administrative connection.
