Can RoboTask read text of ToolTip(s)
User avatar
robotask
Post by robotask »
For example, hovering the mouse over the systray area of RT icon would display a tooltip "RoboTask 5.6.4.809"
Can RoboTask read this and store mouse coordinates ?
Re: Can RoboTask read text of ToolTip(s)
I'm afraid that no
Theoretically the tooltip is a window with own class and title, but it is being opened only if you place mouse cursor over corresponding element.
User avatar
robotask
Post by robotask »
That is precisely what I am proposing to do
1. Loop all Systray icons via a Do - End Loop, moving 1 pixel at a time with some Wait 2 to 3 seconds between
2. If a ToolTip, any text, any icon, displays, write it to a file with the Mouse X and Y coordinates
User avatar
robotask
Post by robotask »
Here is a sample that loops all hidden and child and writes to a text file
This works except that I really do not want empty captions and tried using Length({wname}) and I also do not have a WhereIsMouse X Y saved
Name=STRING|"Create local variable ""WH"" with value """""
varname=STRING|"WH"
Name=STRING|"Create local variable ""WNAME"" with value """""
varname=STRING|"WNAME"
ActionID=STRING|"A_LOOP_WINDOW"
Name=STRING|"Window Loop"
caption=STRING|"1"
captionexact=STRING|"0"
captionfilter=STRING|"0"
captionvariable=STRING|"WNAME"
class=STRING|"0"
classexact=STRING|"0"
classfilter=STRING|"0"
handlevariable=STRING|"WH"
showchild=STRING|"1"
showhidden=STRING|"1"
operator=STRING|"3"
value1=STRING|"Length({wname})"
value2=STRING|"1"
Name=STRING|"Create text file e:\temp\windows.txt"
encode=STRING|"0"
fileexists=STRING|"1"
filname=STRING|"e:\temp\windows.txt"
line0=STRING|"{wname}"
suppress=STRING|"0"
