String to Interger
AngeloScuro
String to Interger
Post by AngeloScuro »
How can I change a string value to an integer?
for example I have a string {TIMEEDITMIN} that contains "10" but when I try to use IF...THEN and compare it as a number I get an error saying "Value "TIMEEDITMIN" it is not a number value."
Re: String to Interger
I'm afraid that your variable contain a non integer value. Maybe some other extra symbols or empty value.
Try to put "Show Message" action before if-then with expression |{TIMEEDITMIN}|
You should see |10|
This error means that the current value can't be transformed into into numeric value. As a rule this value is empty or contains incorrect symbols
Maybe you put variable without {}. In this case the action uses the expression AS IS. Show me your example.
Look my example below. It uses correct and incorrect values:
CatID=INTEGER|1239974297
ExternalName=STRING|"Task625"
ID=INTEGER|643905856
Name=STRING|"If Then..."
Name=STRING|"Create local variable ""AAA"" with value ""{chr(32)}10{chr(32)}{EOL}"""
varname=STRING|"AAA"
varvalue=STRING|"{chr(32)}10{chr(32)}{EOL}"
type=STRING|"1"
value1=STRING|"{aaa}"
value2=STRING|"10"
Name=STRING|"Show ""Value is 10"""
msg0=STRING|"Value is 10"
Name=STRING|"Set variable ""AAA"" with value """""
type=STRING|"1"
value2=STRING|"10"
Save the text of task into a file and use menu Task -> Import
