Wait for task : output code
Vara04
Post by Vara04 »
How to know, when there is a timeout in task item ("Wait for task" for example), if the item continue after timeout or after the end of the task ?
Maybe a solution is to add a variable to save the state of end of the waiting task item (in "Wait for task") ?
Chris
(Robotask v6.4.2 on Win2008 x64)
Re: Wait for task : output code
If timeout is over then the action generates the error "Timeout is over"
By default this terminates the task execution.
Of course you can handle this error by using error handler
Vara04
Post by Vara04 »
Ok
I did not notice that there was this possibility.
Chris
