Is Choice list possible
User avatar
robotask
Post by robotask »
Is there a function to populate a list of choices, from which one item can be selected and stored into a variable ?
Example: Populate a list with Selections A, B, C, display the list and select B with a mouse click, variable vSelected would now contain B
Re: Is Choice list possible
Look at this example
It requires Basic plugin. Just download and install it if it's necessary.
Save the task into a file and use menu Task->Import to import into RoboTask.
