unable to sert schedule trigger
KevinU
Post by KevinU »
set schedule for
00:30:00
monthuly on 15th effective 01/06/2013
wont set says never
cange toweekly mon wed fri insted woks
trird on other pc same result
any ideas please
Thanks Kevin
Please note that I suffer from Parkinsons and as a result my posts may contain typos and shouting.
Thank You
Re: unable to sert schedule trigger
Thank you for the report
Maybe this is incorrect displaying only, because the trigger recomputes next start periodically.
We will recheck this.
KevinU
Post by KevinU »
days 1 - 13 display k
all the restt how never , inc last day
hope this helps
Thanks Kevin
Thank You
The "Scheduler" trigger calculates next scheduled time only within next 31 days.
If next "time point" is later than 31 days (after current time) then it writes "never".
Maybe "never" is incorrect word.
Probably it's necessary to change it to "next month" or "not in nearest month"
The trigger works correctly.
KevinU
Post by KevinU »
how about
'next schedue due ...{date}
asyou may need to shedule qtrly job and it would give user valid info rather than 'next month'
Thanks Kevin
Thank You
