have tries seveaal ways to buillde a schedule og tasks taht execute n sequence .
tried all in one task .....
latetsest isssss seperated taaks, these are attached/
shedule flies through all stems but only the 1st run is exeuted.
aaaaaaaaaaaaaam i dounig thingss wrong orx have i maaaaaaaaaaaaaaaaaaaaaaaanged to corrupt something wen i have ahad one of my 'sessionnss'
annny help welecom
tasks not waiting for each othrt
- Attachments
HBK_JOBSTEP_VIRUS.zip
- (10.82 KiB) Downloaded 1583 times
Thanks Kevin
Please note that I suffer from Parkinsons and as a result my posts may contain typos and shouting.
Thank You
Thank You
Re: tasks not waiting for each othrt
If you start the task with waiting you do not need to add Wait for Task action
I tried your tasks. The task HBK_JOB_SCHEDULE_MONTHLY started all other tasks in sequence.
I don't understand your algorithm, because I don't know what external programs do.
the external tasks are bacpups/securities thhh
relate to diffents asspectss
trying to mange manage 1/optimize ti2me2212.
just added the taskdependeces even without get same result
Thanks Kevin
Thank You
Thank You
trying to
creat a snapshot of critical drives
defach
backup
scan for viruses
backup agin
only 1 backup can run at once
defach
backup
scan for viruses
backup agin
Thanks Kevin
Thank You
Thank You
Look at the task "HBK_JOB_SCHEDULE_MONTHLY"
It seem that this task is working infinitely or until you set particular value to variable.
I think that this is not a good idea. It's better to attach some trigger to a task. For example Cyclic.
In order to stop the task at all enough to disable the task. You can do this from another task too ( see Disable Task action)
