not work on anther pc
KevinU
Post by KevinU »
xhave two stemaaaa wrote seveaal taaaaaaaaaaaaaasks on one mc all dependeces wwwork but if i eport and then inport on other pc depebdeses bot rorking
wating for pevious aaaaaaaction /task tto bomplete is maain issue
aaaaaaaaaaaany suggestions
Thanks Kevin
Please note that I suffer from Parkinsons and as a result my posts may contain typos and shouting.
Thank You
Re: not work on anther pc
RoboTask can change the task ID at importing if ID is already exists.
In this case you should reconfigure actions which use another tasks:
- "Enable Task"
- "Disable Task"
- "Start Task"
- "Stop Task"
- "Wait for Task"
