can robotask automatically logon to domain ?
User avatar
robotask
Post by robotask »
Normally, when a system is restarted (windows update, patches from corporate domain, dll updates, etc), it is necessary to execute logon keystrokes using a default user, ie. Admin@mydomain after CTRL-ALT-DELETE
Can robotask do this automatically, similar to how Automate 9 does it ?
Re: can robotask automatically logon to domain ?
RoboTask can't provide automatically logon into your system.
But you can do this yourself by using command line: control userpasswords2
Next you should uncheck the checkbox "User must enter username and password..." and press Apply button.
See on the screenshot:
On next step you must input the valid password of the user.
This is system feature.
User avatar
robotask
Post by robotask »
that solution will not work on a domain system with group policy in effect.... have to use Automate 9 then for logon...
