Variable not setting properly
Naras
Post by Naras »
I have a task that is looping through several RoboFtp log files to extract when files were sent and if they completed or errored. I'm using a series of if/then statements and str pos to find the info then extract to variables.
The variables are declared locally.
My first if/then looks for sending.
If found, extracts the the characters between " " and stores it in a variable{L_FILE_NAME}
The second set of if/then statements look for upload.
If found, extract certain characters and stores it in variable{L_STATUS}
All of the variables are contained in an output statement assigned to L_OUT. {L_OUT} {L_FILE_NAME} {L_STATUS}{EOL}
There may be several instances where sending/upload is found in each file.
The output will contain the first line where sending matched but will not contain the upload (which will usually be on the next line or so depending on how many files sent). The second and subsequent lines will contain all the info needed.
Thoughst?
Re: Variable not setting properly
It would be great to see the full task.
But I think that you forget to turn ON "Expand variable value now" parameter.
See on screenshot:
This is a very frequent mistake.
Naras
Post by Naras »
Hi Oleg,
Thanks for your help. That doesn't appear to be the issue. I've attached the task.
Naras
CatID=INTEGER|389577733
ExternalName=STRING|"Task438"
ID=INTEGER|1832774599
LocalVariables=STRING|"L_CUR_FILE,L_CHAR_POS,L_MONTH,L_FILE_NAME,L_CUR_LINE,L_OUT,"" L_FILE_NAME"",L_LINE_COUNT,L_TOTAL_LINE_COUNT,L_FOUNDLINE,L_FILE_STATUS,L_FILE_DATE,L_LOG,L_LOG_FILE_NAME,L_LINE_DATE,L_YEAR,L_MONTH,L_DAY,L_NEW_DATE,L_F_CHAR,L_CURR_STATUS,L_DL_STATUS,L_UL_STATUS"
Name=STRING|" Scan  FTP LOGS "
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Action28=FOLDER
Action29=FOLDER
Action30=FOLDER
Action31=FOLDER
Action32=FOLDER
Action33=FOLDER
Action34=FOLDER
Action35=FOLDER
Action36=FOLDER
Action37=FOLDER
Action38=FOLDER
Action39=FOLDER
Action40=FOLDER
Action41=FOLDER
Action42=FOLDER
Action43=FOLDER
Action44=FOLDER
Action45=FOLDER
Action46=FOLDER
Action47=FOLDER
Action48=FOLDER
Action49=FOLDER
Action50=FOLDER
Action51=FOLDER
Action52=FOLDER
Action53=FOLDER
Action54=FOLDER
Action55=FOLDER
Action56=FOLDER
Action57=FOLDER
Action58=FOLDER
Action59=FOLDER
Action60=FOLDER
Action61=FOLDER
Action62=FOLDER
Action63=FOLDER
Action64=FOLDER
Action65=FOLDER
Action66=FOLDER
Action67=FOLDER
Action68=FOLDER
Action69=FOLDER
Name=STRING|"//*--Process FTP Sending/Receiving Lines include Status: upload/download/error"
comment=STRING|"*--Process FTP Sending/Receiving Lines include Status: upload/download/error"
Name=STRING|"Text Loop -through Log File"
destvar=STRING|"L_CUR_LINE"
file=STRING|"C:\RoboFTP LOG files\{L_LOG_FILE_NAME}"
linecount=STRING|"0"
sourcetext=STRING|"0"
Name=STRING|"Increment variable ""L_TOTAL_LINE_COUNT"""
incement=STRING|"1"
vaiable=STRING|"L_TOTAL_LINE_COUNT"
Name=STRING|"Set variable ""L_LOGID"" with value ""{ExtractFileName({L_CUR_FILE})}"""
[Actions\Action12\Params]
varname=STRING|"L_LOGID"
varvalue=STRING|"{ExtractFileName({L_CUR_FILE})}"
Name=STRING|"STR Extract first 2 chars from current file name assign to L_F_CHAR"
[Actions\Action13\Params]
amount=STRING|"2"
from=STRING|"1"
source=STRING|"{ExtractFileName({L_CUR_FILE})}"
variable=STRING|"L_F_CHAR"
[Actions\Action14]
Name=STRING|"Set variable ""L_FOUNDLINE"" with value ""F"""
[Actions\Action14\Params]
varname=STRING|"L_FOUNDLINE"
varvalue=STRING|"F"
[Actions\Action15]
Name=STRING|"Set variable ""L_CURR_STATUS"" with value """""
[Actions\Action15\Params]
varname=STRING|"L_CURR_STATUS"
[Actions\Action16]
Name=STRING|"//*---Process the Date--"
[Actions\Action16\Params]
comment=STRING|"*---Process the Date--"
[Actions\Action17]
Name=STRING|"STR Extract - Year"
[Actions\Action17\Params]
amount=STRING|"5"
from=STRING|"1"
source=STRING|"{L_CUR_LINE}"
variable=STRING|"L_YEAR"
[Actions\Action18]
Name=STRING|"STR Extract - Month"
[Actions\Action18\Params]
amount=STRING|"2"
from=STRING|"7"
variable=STRING|"L_MONTH"
[Actions\Action19]
Name=STRING|"STR Extract - Day"
[Actions\Action19\Params]
amount=STRING|"2"
from=STRING|"10"
variable=STRING|"L_DAY"
message=STRING|"LOGID: {TaskName}"
[Actions\Action20]
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
[Actions\Action20\Params]
custom=STRING|"1"
customchar=STRING|"["
eol=STRING|"0"
lead=STRING|"1"
source=STRING|"{L_YEAR}"
spaces=STRING|"0"
tabs=STRING|"0"
trailing=STRING|"0"
[Actions\Action21]
Name=STRING|"Set variable ""L_LINE_DATE"" with value ""{L_YEAR}/{L_MONTH}/{L_DAY}"""
[Actions\Action21\Params]
varname=STRING|"L_LINE_DATE"
varvalue=STRING|"{L_YEAR}/{L_MONTH}/{L_DAY}"
[Actions\Action22]
Name=STRING|"//*---See if Date Matches "
[Actions\Action22\Params]
comment=STRING|"*---See if Date Extracted Matches Yesterday"
[Actions\Action23]
Name=STRING|"If Then L_NEW_DATE = L_LINE_DATE process lines"
[Actions\Action23\Params]
value1=STRING|"{L_LINE_DATE}"
value2=STRING|"{L_NEW_DATE}"
[Actions\Action24]
Name=STRING|"Increment variable ""L_LINE_COUNT"""
[Actions\Action24\Params]
incement=STRING|"1"
vaiable=STRING|"L_LINE_COUNT"
[Actions\Action25]
Name=STRING|"//*---Process lines that contain Receiving, Sending, Upload, Download, File"
[Actions\Action25\Params]
comment=STRING|"*---Process lines that contain Receiving, Sending, Upload, Download, File"
[Actions\Action26]
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos sending found assign to L_CHAR_POS"
[Actions\Action26\Params]
case=STRING|"1"
from=STRING|"1"
search=STRING|"Sending"
variable=STRING|"L_CHAR_POS"
[Actions\Action27]
Name=STRING|"If Then L_CHAR_POS of Sending"
[Actions\Action27\Params]
case=STRING|"1"
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{L_CHAR_POS}"
value2=STRING|"0"
[Actions\Action28]
Name=STRING|"STR Extract assign to L_FILE_DATE"
[Actions\Action28\Params]
amount=STRING|"16"
from=STRING|"2"
variable=STRING|"L_FILE_DATE"
[Actions\Action29]
ActionID=STRING|"A_STR_BETWEEN"
Name=STRING|"STR Between "" and "" assign to L_FILE_NAME"
[Actions\Action29\Params]
begin=STRING|""""
end=STRING|""""
save=STRING|"0"
startpos=STRING|"1"
variable=STRING|"L_FILE_NAME"
Name=STRING|"//*--Date is set for Yesterday YYYY/MM/DD"
comment=STRING|"*--Date is set for Yesterday YYYY/MM/DD"
[Actions\Action30]
Name=STRING|"Set variable ""L_FOUNDLINE"" with value ""T"""
[Actions\Action30\Params]
varvalue=STRING|"T"
[Actions\Action31]
[Actions\Action32]
Name=STRING|"STR Pos -*Upload"
[Actions\Action32\Params]
from=STRING|"1"
search=STRING|"*Upload"
[Actions\Action33]
Name=STRING|"If Then *Upload "
[Actions\Action33\Params]
operator=STRING|"3"
type=STRING|"1"
value2=STRING|"0"
[Actions\Action34]
Name=STRING|"STR Extract L_CUR_LINE assign to L_UL_STATUS"
[Actions\Action34\Params]
amount=STRING|"256"
from=STRING|"37"
variable=STRING|"L_UL_STATUS"
[Actions\Action35]
[Actions\Action36]
Name=STRING|"STR Pos -*File upload error"
[Actions\Action36\Params]
case=STRING|"1"
from=STRING|"1"
search=STRING|"*File upload error"
[Actions\Action37]
Name=STRING|"If Then File Upload Error"
[Actions\Action37\Params]
operator=STRING|"3"
type=STRING|"1"
value2=STRING|"0"
[Actions\Action38]
[Actions\Action38\Params]
amount=STRING|"256"
from=STRING|"37"
[Actions\Action39]
Name=STRING|"Set variable ""L_NEW_DATE"" with value ""{YearIncDays(-1)}/{MonthIncDays(-1)}/{IncDays(-1)}"""
varname=STRING|"L_NEW_DATE"
varvalue=STRING|"{YearIncDays(-1)}/{MonthIncDays(-1)}/{IncDays(-1)}"
[Actions\Action40]
Name=STRING|"STR Pos receiving found assign to L_CHAR_POS"
[Actions\Action40\Params]
case=STRING|"1"
from=STRING|"1"
search=STRING|"Receiving"
[Actions\Action41]
Name=STRING|"If Then  L_CHAR_POS of Receiving"
[Actions\Action41\Params]
case=STRING|"1"
operator=STRING|"3"
type=STRING|"1"
value2=STRING|"0"
[Actions\Action42]
[Actions\Action42\Params]
amount=STRING|"16"
from=STRING|"2"
[Actions\Action43]
[Actions\Action43\Params]
begin=STRING|""""
end=STRING|""""
save=STRING|"0"
startpos=STRING|"1"
[Actions\Action44]
[Actions\Action44\Params]
varvalue=STRING|"T"
[Actions\Action45]
[Actions\Action46]
Name=STRING|"STR Pos -*Download "
[Actions\Action46\Params]
from=STRING|"1"
search=STRING|"*Download"
[Actions\Action47]
Name=STRING|"If Then *Download"
[Actions\Action47\Params]
operator=STRING|"3"
type=STRING|"1"
value2=STRING|"0"
[Actions\Action48]
Name=STRING|"STR Extract L_CUR_LINE assign to L_DL_STATUS"
[Actions\Action48\Params]
amount=STRING|"256"
from=STRING|"37"
variable=STRING|"L_DL_STATUS"
[Actions\Action49]
Name=STRING|"//*--Set Date for a specific day within the file loop period: Leave unchecked if using Yesterday as parameter"
comment=STRING|"*--Set Date for a specific day within the file loop period"
[Actions\Action50]
Name=STRING|"//*---End Process lines in file"
[Actions\Action50\Params]
comment=STRING|"*---End Process lines in file"
[Actions\Action51]
Name=STRING|"//*---Gather Output Info"
[Actions\Action51\Params]
comment=STRING|"*---Gather info and send it to L_OUT"
[Actions\Action52]
Name=STRING|"If Then ul"
[Actions\Action52\Params]
value1=STRING|"{L_F_CHAR}"
value2=STRING|"ul"
[Actions\Action53]
Name=STRING|"Set variable ""L_CURR_STATUS"" with value ""{L_UL_STATUS}"""
[Actions\Action53\Params]
varvalue=STRING|"{L_UL_STATUS}"
[Actions\Action54]
[Actions\Action55]
Name=STRING|"If Then dl"
[Actions\Action55\Params]
value2=STRING|"dl"
[Actions\Action56]
Name=STRING|"Set variable ""L_CURR_STATUS"" with value ""{L_DL_STATUS}"""
[Actions\Action56\Params]
varvalue=STRING|"{L_DL_STATUS}"
[Actions\Action57]
[Actions\Action58]
Name=STRING|"If Then -L_FOUNDLINE = T"
[Actions\Action58\Params]
value1=STRING|"{L_FOUNDLINE}"
value2=STRING|"T"
[Actions\Action59]
Name=STRING|"Set variable ""L_OUT"" with value ""{L_OUT} Date/Time Sent: {L_FILE_DATE} Log File Nam..."""
[Actions\Action59\Params]
varname=STRING|"L_OUT"
varvalue=STRING|"{L_OUT} Date/Time Sent: {L_FILE_DATE} Log File Name: {L_LOGID} {EOL} File Sent/Recieved: {L_FILE_NAME} File Status: {L_CURR_STATUS}{EOL}{EOL}"
Name=STRING|"Set variable ""L_NEW_DATE"" with value ""2013/04/02"""
varvalue=STRING|"2013/04/02"
[Actions\Action60]
[Actions\Action61]
Name=STRING|"Set variable ""L_FILE_NAME"" with value """""
[Actions\Action61\Params]
varname=STRING|"L_FILE_NAME"
[Actions\Action62]
Name=STRING|"Set variable ""L_FILE_DATE"" with value """""
[Actions\Action62\Params]
varname=STRING|"L_FILE_DATE"
[Actions\Action63]
Name=STRING|"Set variable ""L_LOGID"" with value """""
[Actions\Action63\Params]
[Actions\Action64]
Enabled=INTEGER|0
Name=STRING|"Set variable ""L_FILE_STATUS"" with value """""
[Actions\Action64\Params]
varname=STRING|"L_FILE_STATUS"
[Actions\Action65]
Name=STRING|"End If - Date Process loop"
[Actions\Action66]
Name=STRING|"End Loop - through log file"
[Actions\Action67]
Name=STRING|"End Loop through RoboFTP folder"
[Actions\Action68]
Name=STRING|"Create text file C:\scann\L_MAILFILE.txt"
[Actions\Action69]
[Actions\Action69\Params]
message=STRING|"Process complete.  Processed {L_LINE_COUNT} lines of {L_TOTAL_LINE_COUNT}."
Name=STRING|"//*--File loop set for files newer than 1 month"
comment=STRING|"*--File loop set for files newer than 1 month"
Name=STRING|"File Loop - through RoboFTP log folder"
createmode=STRING|"2"
createormodified=STRING|"1"
date1=STRING|"20130214"
date2=STRING|"20130214"
destvar=STRING|"L_CUR_FILE"
DuringDays=STRING|"10"
DuringMinutes=STRING|"1"
DuringMonths=STRING|"4"
file0=STRING|"C:\RoboFTP LOG files\*.log"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""L_LOG_FILE_NAME"" with value ""{ExtractFileName({L_CUR_FILE})}"""
varname=STRING|"L_LOG_FILE_NAME"
Why the step #68 (Create text file C:\scann\L_MAILFILE.txt) have no parameters?
What is the text body?
Could you send a couple of log files to my private mail (oleg(at)robotask.com) for testing?
Naras
Post by Naras »
Hi Oleg,
The text body is the value of {L_OUT}.
Sent testing files to email provided.
Thanks
Naras
Thank yoiu for your examples
I got such file:
 Date/Time Sent: 2013-04-02 10:20 Log File Name: dl_script_sample.log
 File Sent/Recieved: Filename File Status:
 File Sent/Recieved:  File Status:
 File Sent/Recieved: Filename File Status: :*Download complete, 3 files received.
 Date/Time Sent: 2013-04-02 16:12 Log File Name: ul_script_sample.log
 File Sent/Recieved: Filename.txt File Status:
 File Sent/Recieved: Filename.txt File Status: :*Upload complete, 1 file sent.
It seems the result is correct.
Naras
Post by Naras »
HI Oleg,
I guess my question is why doesn't the File Status set on lines (2 , 5 & 8) of the dl file and line 27 of the ul file in your example?
Naras
Unfortunately you use a very complicated algorithm...
I guess that this can be simplified.
You assign variable only in one step (#48)
Look at the steps #46-#49
You try to find substring *Download
Look at the line in the log:
[2013-04-02 10:20:32,407:0x000022d8]:*Receiving to "Filename"
This string doesn't contain substring *Download, so you get the empty variable and empty status
You can find *Download only at 4-th line.
Another remark: you should reset the L_DL_STATUS to empty value at the end of the loop (or at the beginning of the loop).
Next lines of your log (5, 6, 7) contain incorrect value (*Download complete, 3 files received) This should be empty too.
Naras
Post by Naras »
Hi Oleg,
Thanks very much for all your help. I'll continue to look for a way to process the info!
Naras
