Need help copying from excel sheet
ecjr72
Post by ecjr72 »
Hello I'm testing robotask to see if it will do this task for me. If it does I will purchase. I need to copy a cell from an excel sheet move it online and save it, then return to the excel sheet and copy the next cell and do the same thing. I need this to continue until all cells have been copied. I am brand new so I would love a simple explanation. I can make it go through the first loop but can't make it copy the next cell down. Thanks so much!
Look at this example
This example copies four columns in succession from Excel document to notepad.
The task copies all rows to the end of table
I hope that this example will help you to compose your own task
How to use:
- Open (or create) Excel document,
- Put cursor on top-left cell of necessary data
- Press Ctrl-Shift-C
Save this task into a file and use menu Task => Import to import this into RoboTask. Do not forget to enable task after importing
lora12
Re: Need help copying from excel sheet
Post by lora12 »
Hi, I am from Australia. I am facing an issue of storing data in my excel sheet. I have a store of sheet sets and trying to manage my data in excel sheet but facing errors I do not understand it is of windows issue or something.
Describe the problem in more details, please
