Arrays
enrgarci
Arrays
Post by enrgarci »
I have a loop that downloads all the files in a directory but a need to create a variable that will hold the name of every file downloaded in the loop so that i can later add this variable in an email. any ideas
Example:
The following files have been downloaded:
file1.txt
file2.txt
file3.txt
Arrays
You may use Write Text File action with append option. If you want save the filename only (without path) use the expression like this: {ExtractFileName({ftpfile})}.
Next you can use the File Loop or TextFile(<File_Name>) macrofunction.
See example below:
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1664541561
ExternalName=STRING|"Task179"
ID=INTEGER|1710315732
Name=STRING|"Download from FTP demo (1)"
ActionID=STRING|"A_FTP_LOGON"
Name=STRING|"FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"0"
port=STRING|"21"
username=STRING|"anonymous"
ActionID=STRING|"A_FTP_TRANSFERTYPE"
Name=STRING|"FTP Transfer Type"
binary=STRING|"1"
Name=STRING|"FTP File Loop"
filenameonly=STRING|"0"
folder=STRING|"/myweb/*.*"
sizesave=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"0"
varname=STRING|"FTPFILE"
ActionID=STRING|"A_FTP_DOWNLOAD"
Name=STRING|"FTP Download"
file=STRING|"{FTPfile}"
folder=STRING|"C:\ftpfiles"
Name=STRING|"Create text file c:\ftpfiles\list.txt"
fileexists=STRING|"1"
filname=STRING|"c:\ftpfiles\list.txt"
line0=STRING|"{ExtractFileName({ftpfile})}"
ActionID=STRING|"A_FTP_LOGOFF"
Name=STRING|"FTP Log Off"
enrgarci
Arrays
Post by enrgarci »
But how can i enter values to the array in the loop? is this posible?
Arrays
It is not possible to add line to user variable directly now. We'll add this feature in next version.
But you can create a multiline text by using the Write Text File action. Later you can load this text to variable by means of TextFile macrofunction.
Arrays
Sorry, I was mistaken.
I wanted to say: Next you can use the Text Loop action or TextFile(<File_Name>) macrofunction.
