A very simple task I believe
mix624
Post by mix624 »
Hi,How would I automate pasting pictures into the same folder ?Lets say I need to paste the same picture into a folder 188 times.How would I do that ?I tried recording mouse didnt work.Those automation softwares are really difficult to understand.
Do you want to put image file to folder 188 times? Why?
If you will copy the same file it will be overwritten every time...
Maybe I don't understand your goal...
