Robotask Backup
zherman
Robotask Backup
Post by zherman »
Dear Support,   How do I backup of all my tasks in one go? instead of backing up thetask one by one?thanks.
Robotask Backup
You can backup all files in tasks folder: tasks and task tree
How to find tasks folder see on screenshots below
For Application mode:
For System service mode:
simona70
Robotask Backup
Post by simona70 »
But passing script from standalone to service there is come problem?
simona70
Robotask Backup
Post by simona70 »
Startup becomes very slow...
theimer
Re: Robotask Backup
Post by theimer »
It is also necessary transfer global variables - export from old computer and import on new computer. Just for info :o)
Okeleso
Re: Robotask Backup
Post by Okeleso »
Oleg wrote:You can backup all files in tasks folder: tasks and task tree
Thanks for tutorial!
elwayfan446
Re: Robotask Backup
Post by elwayfan446 »
So, long story short... my PC had to be reimaged, however, they saved a copy of my old profile which included my AppData folder and the Robotask folder. I see my tasks in the tasks folder but when I open Robotask, it is empty, none of my tasks appear. Does Robotask read that folder on startup or do the tasks have to be reimported? Also, are those tasks saved there anytime they are updated or do they have to be exported every time?
Re: Robotask Backup
Does Robotask read that folder on startup ...
Yes, RoboTask reads task folder when it starts.
...but when I open Robotask, it is empty, none of my tasks appear.
Check please, probably the default task folder is different for your current profile. But you can change it manually and restart RoboTask.
... are those tasks saved there anytime they are updated ...
RoboTask saves the task file every time when the task changed
elwayfan446
Re: Robotask Backup
Thanks Oleg... looks like I just needed to close and reopen. I appreciate it.
gmcfarlane
Re: Robotask Backup
Post by gmcfarlane »
it is important that you also copy cats.tree from the source
this is how rt knows how to arrange your tasks in folders
the inability to restore the configuration easily on another machine is the main reason i get pushback everytime i suggest using rt in more places.
there is not a good export instance/import instance and it really makes rt look like an inadequate tool
i wish something could be done. i think rt is a great value , but as it sits, it has a perception problem.
