Remove sub level folders
rice1973
Post by rice1973 »
Hello Oleg,
I need to remove sub level folders eg;
"387.60.009/Images/387.60.009/Lv2/*.*" ("*.*" are the
files)
Has to become;
"387.60.009/*.*" ("*.*" are the files)
So removed must be the folders "Images/387.60.009/Lv2"
but the "*.*" (are the files) must keep existing.
So content that is is "387.60.009/Images/387.60.009/Lv2/"
has to "move" to "387.60.009/"
Do you guarantee that conflict of filenames will not appear?
How many sublevel folders in each folder?
rice1973
Post by rice1973 »
Only the folder names containing the numbers change;
eg "387.60.009" can be "421.50.212" or "352.51.230".
Sublevels from top to bottom;
"387.60.009" contains folders "Images" and "HTML5" (this
folder must also be removed)
"Images" contains only folder "387.60.009"
"387.60.009" contains only folder "Lv2"
Maybe it's quicker / easier to move the content from
"387.60.009/Images/387.60.009/Lv2/" to "387.60.009"
(first folder) and then remove all the subfolders
rice1973
Post by rice1973 »
Hello Oleg,
Can you hel me with the solution for above?
See the example below.
Algorithm is simple. I thought that you can compose this task yourself...
CatID=INTEGER|2099193306
ExternalName=STRING|"Task14"
ID=INTEGER|1967261896
Name=STRING|"Remove sublevels"
Name=STRING|"Create local variable ""ROOTFOLDER"" with value ""d:\387.60.009"""
varname=STRING|"ROOTFOLDER"
varvalue=STRING|"d:\387.60.009"
Name=STRING|"Create local variable ""CURRENTFOLDER"" with value """""
varname=STRING|"CURRENTFOLDER"
Name=STRING|"Create local variable ""CURRENTFILE"" with value """""
varname=STRING|"CURRENTFILE"
Name=STRING|"File Loop"
date1=STRING|"20130117"
date2=STRING|"20130117"
destvar=STRING|"CURRENTFOLDER"
DuringMinutes=STRING|"1"
file0=STRING|"{rootfolder}\*.*"
searchkind=STRING|"1"
subdirs=STRING|"0"
timesize=STRING|"0"
destvar=STRING|"CURRENTFILE"
file0=STRING|"{currentfolder}\*.*"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{rootfolder}"
f_count=STRING|"1"
file0=STRING|"{CurrentFile}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
type=STRING|"1"
value1=STRING|"{FilesCount({currentfolder})}"
value2=STRING|"0"
Name=STRING|"Remove Nonempty Folder ({currentfolder})"
deletefolder=STRING|"1"
folder=STRING|"{currentfolder}"
rice1973
Post by rice1973 »
I am not that far .
mmh, the "d:\387.60.009" is a variable.(every folder has
another number "***.**.***")
How to fix that?
You should do another one loop by folders by using the mask d:\???.??.???
* - any amount of any symbols
? - one any symbol
rice1973
Post by rice1973 »
I will try ro fix it.
rice1973
Post by rice1973 »
Wrong post...
rice1973
Post by rice1973 »
Hello Oleg,
Can't find the "mistake". Can you look?
CatID=INTEGER|0
Name=STRING|"Remove sublevels (imported)"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
destvar=STRING|"ROOTFOLDER"
file0=STRING|"D:\???.??.???"
subdirs=STRING|"0"
timesize=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
f_count=STRING|"1"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
[Actions\Action12\Params]
type=STRING|"1"
value2=STRING|"0"
[Actions\Action13\Params]
[Actions\Action14]
[Actions\Action15]
[Actions\Action16]
file0=STRING|"D:\3dmap\???.??.???"
subdirs=STRING|"0"
timesize=STRING|"0"
operator=STRING|"6"
value1=STRING|"{Rootfolder({currentfolder})}"
value2=STRING|"0"
value """""
value """""
subdirs=STRING|"0"
timesize=STRING|"0"
