Randomly Scheduling A Task
julian926
Post by julian926 »
Newbie here. How does someone randomly schedule a task
from, say, 9:00 - 9:30 am?
Thank you!
Julian
What do you want to get exactly?
- Run once or several times between 9:00 to 9:30;
- Why do you not want to use ordinary scheduler?
julian926
Post by julian926 »
Thanks for the reply. I want to run every day.
I had thought robotask has some kind of randomizer and the
ability to schedule. Am I wrong?
Thanks!
You can put random pause at the beginning of the task.
See the example below:
CatID=INTEGER|2099193306
ExternalName=STRING|"Task72"
ID=INTEGER|1416894126
Name=STRING|"Random schedule"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"{RandomValue(60)}"
Name=STRING|"Delay 15000 ms"
delay=STRING|"150"
msg1=STRING|"Hey, awake!"
msg3=STRING|"(do something here)"
msgcount=STRING|"4"
UnigueID=INTEGER|1635073
id=STRING|"1OKQK185"
periodicity=STRING|"0"
startdate=STRING|"41289"
time0=STRING|"32400000"
timecount=STRING|"1"
julian926
Post by julian926 »
Thanks again! Dumb question - where can I view it in code
view?
Save the text of the task to a file and use menu Task => Import in order to import the task into RoboTask.
