Issue with Move to Object Mouse Function
zherman
Post by zherman »
Dear All,I've found out that there's an issue with Move to Object.The application that I need to automate via this function isa java application.  When I created the task project, everything seems to be running well.. but after a few days of successfully running the task. It will give me an error saying that the object not found. etc...PS. from the processes I can see that the java application is highlighted. Please help.Deddy
Probably your window changed the caption. You should specify only permanent part of the title.
For example:
Book1 - Microsoft Excel
Test - Microsoft Excel
You should specify "Microsoft Excel" as part of window title.
Maybe the necessary control element (e.g. Button) has changed own parameters. This possible if you updated this application to new version.
In any case I recommend you to reconfigure "Move to Object" step.
zherman
Post by zherman »
Thanks for the reply you are correct.
