It then merges some PDFS generates alist of the files and emails it out then it moves the PDFs into some folders
Everything works except the email doesn't include the variable which is a list of filenames.
I created a standalone task and it works fine
I then cut & paste it into the task and the email is sent put the variableis missing?
Steps 10 - 14 are where the problems lies.
But they are identical to the standalone task which works fine
CatID=INTEGER|0
ContinueOnError=INTEGER|1
ExternalName=STRING|"Task4"
ID=INTEGER|1610418628
LocalVariables=STRING|"NUMFILES,INTPLANT,EXTPLANT,WAGES,SOUR CE,WEEKLY"
Name=STRING|"Watch for 5 files"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Name=STRING|"Check Wages"
value1=STRING|"{FileExists(d:\costs\wages\wages.txt)}"
value2=STRING|"1"
Name=STRING|"Looks for Merged PDFs"
createmode=STRING|"5"
date1=STRING|"20050921"
date2=STRING|"20050921"
destvar=STRING|"NOOFILES"
DuringDays=STRING|"28"
DuringMinutes=STRING|"1"
file0=STRING|"d:\costs\record\*.pdf"
OlderDays=STRING|"28"
searchkind=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
WithoutPath=STRING|"1"
Name=STRING|"Grab contract names"
amount=STRING|"4"
from=STRING|"12"
source=STRING|"{NOOFILES}"
variable=STRING|"noofiles"
Name=STRING|"Append list"
[Actions\Action12\Params]
varname=STRING|"ALLFILES"
varvalue=STRING|"<br> {ALLFILES} {noofiles}</br>"
[Actions\Action14]
Name=STRING|"Send Email with file list"
[Actions\Action14\Params]
attachcount=STRING|"0"
auth=STRING|"0"
charset=STRING|"iso-8859-1"
from=STRING|"costs@rjmcleod.co.uk"
host=STRING|"172.16.64.3"
html=STRING|"1"
msg0=STRING|"<p>The following cost files have been merged and moved</p>"
msg1=STRING|"<p>Please check <a href=""file://///dingdc\costs\record"">these folders</a> for the files</p>"
msg2=STRING|"<p>Thank you</p>"
msg4=STRING|"{ALLFILES}"
msgcount=STRING|"5"
password=STRING|"2540125197259642494625963"
passwordmode=STRING|"0"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"Costs Merged"
to=STRING|"deesloop@myemail.co.uk"
[Actions\Action15]
Name=STRING|"Run Move to folders script"
[Actions\Action15\Params]
line00000=STRING|"Sub Main"
line00001=STRING|"Dim objshell"
line00002=STRING|"Dim objFSO"
line00003=STRING|"Dim objResult"
line00004=STRING|"Dim objfile"
line00005=STRING|"Dim dayt"
line00006=STRING|"Dim strFolderPath"
line00007=STRING|"Set objshell = CreateObject(""WScript.Shell"")"
line00008=STRING|"Set objFSO = CreateObject(""Scripting.FileSystemObject"")"
line00009=STRING|"On Error Resume Next"
line00010=STRING|"Set objFSO = CreateObject(""Scripting.FileSystemObject"")"
line00011=STRING|"Set objFolder = objFSO.GetFolder(""d:\costs\record"")"
line00012=STRING|"For Each objfile In objFolder.Files"
line00013=STRING|" contract = Mid(objfile.Name, 12, 4)"
line00014=STRING|" folder = Mid(objfile.Name, 12, 2)"
line00015=STRING|" strFolderPath = ""d:\costs\record\"" & folder & ""00-"" & folder & ""99\"""
line00016=STRING|"If Not objFSO.FolderExists(strFolderPath) Then"
line00017=STRING|" Set objFolder2 = objFSO.CreateFolder(strFolderPath)"
line00018=STRING|"End If"
line00019=STRING|" strFolderPath2 = ""d:\costs\record\"" & folder & ""00-"" & folder & ""99\"" & contract & ""\"""
line00020=STRING|"If Not objFSO.FolderExists(strFolderPath2) Then"
line00021=STRING|" Set objFolder2 = objFSO.CreateFolder(strFolderPath2)"
line00022=STRING|"End If"
line00023=STRING|"objFSO.MoveFile objfile.Path, strFolderPath2"
line00024=STRING|"Next"
line00025=STRING|"Set objFSO = CreateObject(""Scripting.FileSystemObject"")"
line00026=STRING|"Set objfile = objFSO.CreateTextFile(""D:\Costs\Finished.txt"")"
line00027=STRING|"End Sub"
linecount=STRING|"28"
source=STRING|"0"
[Actions\Action16]
Name=STRING|"Delete File"
[Actions\Action16\Params]
Count=STRING|"7"
deletedirs=STRING|"0"
file0=STRING|"d:\costs\extplant\*.*"
file1=STRING|"d:\costs\intplant\*.*"
file2=STRING|"d:\costs\source\*.*f"
file3=STRING|"d:\costs\wages\*.*"
file4=STRING|"d:\costs\weekly\*.*"
file5=STRING|"d:\costs\splits\*.*f"
file6=STRING|"d:\costs\*.txt"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
[Actions\Action17]
[Actions\Action18]
[Actions\Action19]
Name=STRING|"Check Costs"
value1=STRING|"{FileExists(d:\costs\weekly\weekly.txt)}"
value2=STRING|"1"
[Actions\Action20]
[Actions\Action21]
Name=STRING|"Check Source"
value1=STRING|"{FileExists(d:\costs\source\source.txt)}"
value2=STRING|"1"
Name=STRING|"Check Intplant"
value1=STRING|"{FileExists(d:\costs\intplant\intplant.txt)}"
value2=STRING|"1"
Name=STRING|"Check Extplant"
value1=STRING|"{FileExists(d:\costs\extplant\extplant.txt)}"
value2=STRING|"1"
Name=STRING|"Run PDF Merge script"
line00001=STRING|"Dim objResult"
line00002=STRING|"Dim objfile"
line00003=STRING|"Dim dayt"
line00004=STRING|"Dim strFolderPath"
line00005=STRING|"Set objShell = CreateObject(""WScript.Shell"")"
line00006=STRING|"Set objFSO = CreateObject(""Scripting.FileSystemObject"")"
line00007=STRING|"Set oFolder=objFSO.getfolder(""d:\costs\splits"")"
line00008=STRING|"On Error Resume Next"
line00009=STRING|"For Each aFile In oFolder.Files"
line00010=STRING|" If sNewest = """" Then"
line00011=STRING|" Set fNewest = aFile"
line00012=STRING|" sNewest = aFile.Name"
line00013=STRING|" Else"
line00014=STRING|" If fNewest.DateCreated < aFile.DateCreated Then"
line00015=STRING|" Set fNewest = aFile"
line00016=STRING|" End If"
line00017=STRING|" End If"
line00018=STRING|"Next"
line00019=STRING|"dayt=(Left(fNewest.Name,10))"
line00020=STRING|"Set objfile = objFSO.CreateTextFile(""D:\Costs\started.txt"")"
line00021=STRING|"For lp = 1500 To 2500"
line00022=STRING|"objResult = objShell.Run(""c:\pdftk.exe d:\costs\splits\????-??-??_"" & lp & ""*.pdf cat output d:\costs\record\"" & dayt & ""_"" & lp & ""_costs.pdf"", 1, True)"
line00023=STRING|"Next"
line00024=STRING|"End Sub"
linecount=STRING|"25"
source=STRING|"0"
Name=STRING|"Wait 2 minutes"
delay=STRING|"1200"
Name=STRING|"Create local variable ""ALLFILES"" with value """""
Name=STRING|"Create local variable ""NOOFILES"" with value """""
varname=STRING|"NOOFILES"
UnigueID=INTEGER|1840797834
id=STRING|"A020OJP5"
interval=STRING|"30"
