deesloop
Posts: 70 Joined: Wed Feb 25, 2009 3:44 am
Post
by deesloop » Wed Dec 12, 2012 11:34 am
You are so quick to respond to issues and I'd like to thank you for that. So here is another (simple) problem for you.
A folder has files init as follows
Date_1234.pdf
Date_1235.pdf
Date_1236.pdf
Date_1238.pdf
Date_1250.pdf
So I want to generate a list of all the files in the folder and truncate the result and email it. So the user gets the following
The following files were updated, please check them out.
1234
1235
1236
1238
1250
I can I believe assign the contents to a variable and email that, but it's the manipulating of the variable I neeed.
Thanks once again for your time and effort
deesloop
Post
by deesloop » Wed Dec 12, 2012 11:35 am
Subfolders is not required.
I just want to truncate the names of the files and dont need the file patch or suchlike either.
deesloop
Post
by deesloop » Wed Dec 12, 2012 1:41 pm
Woohoo
Sorted this myself
The variable {} are throwing me
The variable is referred to without brackets
The variables values is referred to with brackets
Doh!
Posts: 3293 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Wed Dec 12, 2012 1:59 pm
See the example below. You can use variable NewList in the message body.
CatID=INTEGER|2099193306
ExternalName=STRING|"Task210"
ID=INTEGER|5850235
Name=STRING|"Truncate names"
Name=STRING|"Create local variable ""LIST"" with value ""Date_1234.pdf {EOL}Date_1235.pdf {EOL}Date_1236.pd..."""
varname=STRING|"LIST"
varvalue=STRING|"Date_1234.pdf {EOL}Date_1235.pdf {EOL}Date_1236.pdf {EOL}Date_1238.pdf {EOL}Date_1250.pdf"
Name=STRING|"Show ""Result list:"""
msg0=STRING|"Result list:"
msg1=STRING|"{NewList}"
msgcount=STRING|"2"
Name=STRING|"Create local variable ""C_FILE"" with value """""
varname=STRING|"C_FILE"
Name=STRING|"Create local variable ""NEWLIST"" with value """""
varname=STRING|"NEWLIST"
Name=STRING|"Show ""Initial list:"""
msg0=STRING|"Initial list:"
msg1=STRING|"{list}"
msgcount=STRING|"2"
Name=STRING|"Text Loop"
destvar=STRING|"C_FILE"
line0=STRING|"{list}"
sourcetext=STRING|"1"
Name=STRING|"Set variable ""C_FILE"" with value ""{ExtractFileNameNoExt({c_file})}"""
varvalue=STRING|"{ExtractFileNameNoExt({c_file})}"
ActionID=STRING|"A_STR_DELETE"
Name=STRING|"STR Delete"
amount=STRING|"5"
from=STRING|"1"
source=STRING|"{c_file}"
variable=STRING|"c_file"
Name=STRING|"Set variable ""NEWLIST"" with value ""{NewList}{c_file}{eol}"""
varvalue=STRING|"{NewList}{c_file}{eol}"
Post
by Oleg » Wed Dec 12, 2012 2:11 pm
Variable name is only the set of chars without braces {}
You have to use braces in other expressions because you should tell RoboTask that expression in braces contains the variable name and RoboTask must calculate the value.
Any strings or words outside of braces will be uses as simple strings as is.
For example:
the expression Today is {date} will be transformed into Today is 12/12/2012
but the expression Today is date will remain the same without changes
Oleg on Wed Dec 12, 2012 6:13 pm, edited 1 time in total.
