Start / Stop Services -- Access is denied
RadioNewark
Post by RadioNewark »
Hello all -- I need to stop and start a Windows service.  DHCP Service, for example.  When I run the [very simple] RoboTask script, I get an Access is denied error message.
I'm running RoboTask interactively under the Administrator account on Windows 2008 Server.  I tried running the GUI with "Run As Administrator."  Still get the Access is denied error.  How can this task be run?  What am I missing?
Thanks a lot,
/sww/
Danndoor
Post by Danndoor »
Try passing the username and password as pert of taskexample :net usrname password stop DHCP
Some operations require rights elevation under Vista/7/2008.
Starting service is one of the such operations.
Operating system decreases user rights by default.
You may solve this so:
- turn OFF UAC (this is NOT recommended)
- run RoboTask "As Administrator". in this case RoboTask obtains FULL rights.
- install RoboTask as system service and use these operations in service. In service mode RoboTask uses rights of SYSTEM account
RadioNewark
Yes, turning off UAC worked fine, but not the answer I was looking for.  Run As Administrator did not work, however.  The original error message Access is Denied continued.
Similarly, installing the RoboTask as a Service under Windows Server 2008 did not allow the task to run either.  The same error message Access is Denied is always logged.
I tried running RoboTask as a Service under the Local System account as well as the Administrator account.  The error was the same under both accounts.
Any other ideas or suggestions?
Thank you,
/sww/
This is impossible
When you run RoboTask "As Administrator" the application gets all possible rights.
I.e. application is working in the same mode as without UAC.
Turning UAC off and running RoboTask "As Administrator" are two similar ways to solve problem of insufficient rights.
