check for process
rgonzalez
check for process
Post by rgonzalez »
would be nice having a check for running process to know if a specific process is running or not and then do some steps according to it.could be the same for services!thank you!
check for process
There is {IsProcessExists()} system variable.
For example {IsProcessExists(notepad.exe)} returns FALSE, if Notepad was not launched. Otherwise
TRUE if Notepad exists in memory.
The variable is in System Info group.
rgonzalez
check for process
Post by rgonzalez »
oh i see it! do we have something for services too?
check for process
Unfortunately no. I wrote about getting service status
feature into our ToDo.
