Trigger a task based on a string
Grady
Post by Grady »
Hello, I am wondering if there is a way to trigger a task based on specifc text entered in to a Hyper Termenal session.  For instance to run a task if someone enters field "7" or starts to enter any text in specifc hyper term field or chnages fields.  Thank you
Unfortunately RoboTask can't capture the inputting into field of another applications now.
