FTP Synchronization and VSS
henrik
Post by henrik »
Hi!Using ver. 5.2 and FTP Synchronization with almost excellent result :). I receive this classical error "E: 26/07/2012 06:26:21: Put File fails with message: Cannot open file "C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG". The process cannot access the file because it is being used by another process."This has to do with Windows not being able to copy open files. The solution is VSS - Volume Shadowing ...... However, how do I make sure that VSS is enabled? I am using Windows XP, Server 2003 and 7.lLooking forward to your reply is Henrik in Fortaleza, Brazil.
You can try "Wait for file" action.
It will stop the task if file is opened by another process and will wait until file will be unlocked.
henrik
Post by henrik »
Oleg wrote:You can try "Wait for file" action.
Thanks for your reply. However, there is not just one file. It is 100 of them, but VSS is not implemented in Robotasl?
