Select local variable
Vara04
Post by Vara04 »
A suggestion:
Have the ability to select local variables in the variable
selection window in {V} of each action
Local variables "lives" only when task is executing, so I'm afraid that it is impossible.
Vara04
Post by Vara04 »
Yes but I think to add a tab "Local variables" and purpose all current task variables
In column Name : text before =
In column Value : text after = (if present)
So when you select a variable, this add a {VariableName} where is the cursor
gavind
Post by gavind »
+1 on this.
Vara04
Post by Vara04 »
Not present in 5.4 :(
Vara04
Re: Select local variable
Post by Vara04 »
Présent in 5.6 Cool ;)
Chris
(Robotask v6.4.2 on Win2008 x64)
