run and renew a crystal report
jeroen123
Post by jeroen123 »
hello Oleg,
I have made a simple task to run , renew and export a chystal report but it seems not so stable: it not always, 1 out of 2 time, renew or export the data well.. can you advise me hoe to make it more stable? thanks!
CatID=INTEGER|0
ExternalName=STRING|"Task18"
ID=INTEGER|458453503
Name=STRING|"AT omzetlijsten vernieuwen en versturen"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Action28=FOLDER
Action29=FOLDER
Name=STRING|"Run ""omzetlijstat.rpt """
ifnonzero=STRING|"0"
program=STRING|"C:\ROBOTASK\omzetlijstat.rpt"
runas=STRING|"0"
wait=STRING|"1"
workdir=STRING|"C:\ROBOTASK"
currentwindow=STRING|"1"
fixedwindow=STRING|"1"
keylayout=STRING|"0"
keys=STRING|"%(T)"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
Name=STRING|"Delay 500 ms"
delay=STRING|"5"
[Actions\Action12\Params]
keys=STRING|"E"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action13\Params]
delay=STRING|"5"
[Actions\Action14]
[Actions\Action14\Params]
keys=STRING|"R"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action15]
[Actions\Action15\Params]
delay=STRING|"5"
[Actions\Action16]
[Actions\Action16\Params]
keys=STRING|"{ENTER}"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action17]
[Actions\Action17\Params]
delay=STRING|"5"
[Actions\Action18]
[Actions\Action18\Params]
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action19]
[Actions\Action19\Params]
delay=STRING|"5"
ActionID=STRING|"A_FILE_WAIT"
Enabled=INTEGER|0
Name=STRING|"Waiting omzetlijstat.rpt file for 3 sec"
filename=STRING|"X:\lijsten\CRYSTAL REPORTS\omzetlijstat.rpt"
timeout=STRING|"3"
[Actions\Action20]
[Actions\Action20\Params]
keys=STRING|"""{DELAY 1000}"",C:\ROBOTASK\omzetlijstAT.pdf,""{DELAY 5000}"",{ENTER}"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action21]
[Actions\Action21\Params]
keys=STRING|"""{DELAY 5000}"",{ENTER}"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action22]
Name=STRING|"Delay 1000 ms"
[Actions\Action22\Params]
delay=STRING|"10"
[Actions\Action23]
[Actions\Action23\Params]
keys=STRING|"%(T)"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action24]
[Actions\Action24\Params]
delay=STRING|"10"
[Actions\Action25]
[Actions\Action25\Params]
keys=STRING|"A"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action26]
[Actions\Action26\Params]
delay=STRING|"10"
[Actions\Action27]
[Actions\Action27\Params]
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
[Actions\Action28]
Name=STRING|"Delay 5000 ms"
[Actions\Action28\Params]
delay=STRING|"50"
[Actions\Action29]
Name=STRING|"Send Email"
[Actions\Action29\Params]
attach0=STRING|"C:\ROBOTASK\omzetlijstat.pdf"
attachcount=STRING|"1"
auth=STRING|"1"
charset=STRING|"iso-8859-1"
from=STRING|"jeanette.d@XXXX"
host=STRING|"dc-container"
html=STRING|"0"
msg0=STRING|"Beste Andre,"
msg1=STRING|"hierbij de lijst van vandaag verstuurde orders,"
msg3=STRING|"Groeten,"
msg4=STRING|"Jeanette"
msgcount=STRING|"5"
password=STRING|"4282XXXXXX"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"Lijst verstuurde Orders {Date}"
to=STRING|"jeroen.s@XXXX.nl"
user=STRING|"jerXXX"
delay=STRING|"50"
keys=STRING|"{F5}"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Crystal Reports - [prijslijst met voorraadgegevens.rpt]"
delay=STRING|"10"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
delay=STRING|"10"
keys=STRING|"ODBC,""{DELAY 1000}"",{ENTER}"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
Name=STRING|"Delay 3000 ms"
delay=STRING|"30"
UnigueID=INTEGER|1787706508
id=STRING|"4H19G4B6"
periodicity=STRING|"1"
periodparameter=STRING|"0111110"
startdate=STRING|"40956"
time0=STRING|"61320000"
timecount=STRING|"1"
I think that you may try to insert "Window command" (with "Focus" parameter) before each "Send Keys" action.
It seems that your window loose its focus while the task is executing.
Also pay attention that you have to avoid pressing the keys and mouse clicks during execution of the task.
