Calculation duration of a task
Bacilioc
Post by Bacilioc »
At the beginning of the task I set a variable as {STARTTIME}={Time} and end of a task variable as {ENDTIME}={Time}. Then through the Basic Evaluate calculates Expression DateDiff ("s", "{STARTTIME}", "{ENDTIME}") but the result is always 0 because {STARTTIME} during execution of the expression is equal to {ENDTIME}! I did the following trick: Create text file TimeSTART.txt with Text: {Time} Action1 Action2 ..... Actinon Create text file TimeEND.txt with Text: {Time} For TimeSTART.txt -> Variable: {STARTIME} End Loop For TimeEND.txt -> Variable: {ENDTIME} End Loop Basic Evaluate -> Expression: DateDiff ("s", "{STARTTIME}", "{ENDTIME}") There is another way of calculating the duration of a task?
Probably you forgot to turn ON "Expand variable value" parameter at Set Variable action.
This is necessary if you want to calculate the expression immediately. Otherwise expressions {StartTime} and {EndTime} will be calculated only before BASIC evaluation. In this case both expressions will be the same.
Look at my example:
CatID=INTEGER|1931015449
ExternalName=STRING|"Task1150"
ID=INTEGER|1517979398
LocalVariables=STRING|"starttime,endtime,diff"
Name=STRING|"task duration"
Name=STRING|"Set variable ""STARTTIME"" with value ""{Time}"""
varname=STRING|"STARTTIME"
varvalue=STRING|"{Time}"
Name=STRING|"Delay 3000 ms"
delay=STRING|"30"
Name=STRING|"Set variable ""ENDTIME"" with value ""{Time}"""
varname=STRING|"ENDTIME"
Name=STRING|"Evaluate"
expression=STRING|"datediff(""s"",""{starttime}"", ""{endtime}"")"
variable=STRING|"DIFF"
Name=STRING|"Show ""Start time: {StartTime}"""
msg0=STRING|"Start time: {StartTime}"
msg1=STRING|"EndTime: {EndTime}"
msg2=STRING|"Time diff: {diff}"
msgcount=STRING|"3"
tdawebdesign
Post by tdawebdesign »
Hi Oleg,Im trying to achieve the same thing.  I need to know how many milli seconds it takes to execute the task.  How would I achieve that?My other question is that when I import your example I get and error on the expression action5.  Is there something I need to install to allow datediff and these functions to be recognised?ThanksTim
