Work problem
bokaking
Work problem
Post by bokaking »
Here's a thing. I need a few things to someone help me with
RT!!!
Recive mail, download att, its a jpg with 23 characters..
like this(karton_5650000000000000) the first 10 characters
are always the same. Whet it dl the file it needs to chk if
its the right name and then upload it to FTP server, if
it's not the right name it need to delete file and send
mail to sender with message that the att. is not valid?
Please help me with this>>>THANKS!!!
Work problem
You should use regular expression in order to check validity of file name.
See the example below:
CatID=INTEGER|1597096124
ExternalName=STRING|"Task1149"
ID=INTEGER|488809097
LocalVariables=STRING|"filename,valid"
Name=STRING|"Check filename"
Name=STRING|"Set variable ""FILENAME"" with value ""kaRTon_5650000000000123.jpg"""
varname=STRING|"FILENAME"
varvalue=STRING|"kaRTon_5650000000000123.jpg"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{filename}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?i)^karton_565[0-9]{13}.jpg$"
savesubexpression=STRING|"0"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"valid"
value1=STRING|"{valid}"
Name=STRING|"Show ""File name {filename}"""
msg0=STRING|"File name {filename}"
msg1=STRING|"is valid"
msgcount=STRING|"2"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
icon=STRING|"3"
msg1=STRING|"is INVALID"
msgcount=STRING|"2"
bokaking
Work problem
Post by bokaking »
thanks, I have one more question... is there a way to DL
mail attachment?
Work problem
You can download the email message from POP3 server and extract attachments from it.
Look at Email group
